Hello Everyone,
I am your newest "newbie"!
I have a problem playing DVDs recorded/burnt on my pc, on any other player. I can play them on the pc but they are not recognised and will not play on my other 'in-house' DVD players.
I used to have Nero 6, but since I upgraded to W7, the Nero programme is not compatible - in fact Nero tell me that nothing from and including Nero 8 downwards is compatible with W7.
I have tried DVD Shrink and Decryptor, CD Burner XP and VLC - all will burn but none of the finished DVDs work on the other DVD players.
Any advice will be gratefully received.
Colinito
Victoriabears,
I have to go out now, but I will download and try later, and come back with the result.
Thank you
Colinito -
What kind of dvd media are you using? Are the dvd's being finalised?
VictoriaBears and Lowellriggsiam,
I have just successfully burnt the DVD onto a TDK DVD-R 4.7 GB using imgBurn.
It plays beautifully on my pc. However, like all the rest - it Does Not Play On my DVD appliances in the rest of the house.
I now give up. I have used up 5 DVDs and have had no success at all. I am no longer prepared to TRY any other options!
My final option is a very tedious one. I have a Combo and I shall copy the DVD onto a Video tape and then, copy the video tape onto a DVD. This takes as long as the DVD lasts - to the Video Tape and to the DVD. It will loose some resolution as it is transferred onto a VHS tape, but no matter, It will end up on a DVD!
Thank you all for your input.
I shall now consider the thread unsolved but Closed!
Colinito
my panasonic standalone dvd can't play pal dvds...but can play pal svcd's
By stoico1 in forum Newbie / General discussionsReplies: 0Last Post: 9th Sep 2009, 16:46 -
Same dvds but not all play identical
By aliefjoker in forum Newbie / General discussionsReplies: 1Last Post: 21st Oct 2008, 10:44 -
Can't play burned DVDs - In need of some serious help!!
By fustrated in forum DVD & Blu-ray PlayersReplies: 13Last Post: 7th Jun 2008, 11:18 -
DVDs won't play on anything
By A Traveller in forum Software PlayingReplies: 3Last Post: 4th Jan 2008, 15:20 -
Is it possible to create dvds that really do play?
By deuxbebes in forum Newbie / General discussionsReplies: 16Last Post: 11th May 2007, 18:18
