Hi all,
There are countless films that have moments where text is displayed but you can't really make it out since it's been deteriorated over the years through multiple generations. Is there a way to repair "damaged" text? I'm sure there is, but I don't know what the process is called or how it's done. Do you somehow just work frame by frame? What's the best way to approach this?
Thanks,
Justin
Results 1 to 9 of 9
It's one of those TV trailers where it mentions at the bottom of the screen that you're viewing actual audience reactions in a theater. I want to fix it.
Hm. It never occurred to me that a new text overlay is a potential solution. I was stuck in the frame of mind of manually touching up each and every pixel, which will drive one mad
I attached two images. The first is the original resolution. The second is the blown up size, which is the one I want to work on. See, the original clip was 320x240 and I'm not satisfied with that. So, I changed the video to 512x384. Unfortunately, that results in data loss... making it look even worse/harder to fix. -
Considering the low resolution, that actually looks pretty good.
Well, keep in mind that I took a single screenshot. The way it looks while it's rolling is a bit different. Plus, I wanted to fix the blown up version, not the original.
I think you're going about this the wrong way, or there could be some improvements in your workflow.
An overlay will work, but it will obscure everything behind in that overlay box, and should be used as a last resort IMO (ie. you don't have a better source, or no other options)
You should seek out the best (as possible) source first, then work with that.
It's obvious in your blowup sample that the pixellation and compression losses - I am going to guess it's been compressed several generations needlessly and/or the filters and compression that you are using aren't ideal.
I blew this up 2x from a crappy youtube sample, no cleanup , cropping or other filtering except for NNEDI2 for the upscaling
Note there's probably better quality trailer material out there (youtube is probably the lowest), and you would get even better results (or if you email the poster, try to get the source material or whatever they uploaded to get 1 generation better).
Your blowup
Youtube , upscaled with avisynth + NNEDI2
Read text create audio and convert text to synced subtitles in mp4
By Philip Lean in forum SubtitleReplies: 1Last Post: 25th Feb 2010, 08:54 -
HELP! Too Much Text - I Need Labelling Template For Text
By kasius in forum MediaReplies: 5Last Post: 6th Dec 2008, 16:08 -
looking for good OCR software that will convert text in jpg to regular text
By jimdagys in forum ComputerReplies: 6Last Post: 27th Jun 2008, 10:38 -
Adding text over original text
By stixster in forum EditingReplies: 3Last Post: 17th Jun 2008, 05:14 -
C# code to save text from listbox to a text file -- SOLVED--
By freebird73717 in forum ProgrammingReplies: 2Last Post: 2nd Sep 2007, 15:50
