Results 1 to 9 of 9
    May 2008
    I was using FAVC to convert a 1080p video( MKV container) to a DVD 5 for my nephew. The conversion stripped off the english subtitles which was in the source . What did I do wrong? Tks
    You must extract the subs and add manually in favc. Use mkvextract or mkvcleaver.
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Or use AVStoDVD for conversion instead. FAVC hasn't been updated in quite some time
    Read my blog here.
    May 2008
    OK Understand. I was disappointed at the results. It took 4 hrs of conversion , then no subtitiles to a Tahi movie ! Yuks . Tks for the info.
  5. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Converting 1080 to DVD is going to cause a large and unavoidable drop in quality as well . . . . .
    4 hours is probably not bad for your system.
    Read my blog here.
    May 2008
    I understand the drop in quality but he's not that fussy. I would not do it for myself, I would do it with 2 DVD's
    I checked media info :
    the video stream is AVC
    Audio stream is DTS
    text stream is UTF-8.
    After I ran AVS2DVD , there was only video , no audio and no subtitles ??
    I had Audio Stream set to Auto , maybe I should set it to AC3 since software cannot handle DTS.
    Did I do something wrong in the settings?
    When I reloaded the file again then opened Title Edit , indeed there was no subtitle present. Maybe it does not recognize the UTF-8 stream? I ran the search and indeed there was no text in the search screen .
    Maybe I just have to extract the subtitle stream ( with subtitle rip ) or try and use DVDFlick instead.
    Definitely need help on this clip.
    May 2008
    I extracted the subtitle and added it to FAVC . After completion, I ran the movie , under subtitles it says there's track 1 but I can't see it. Can it be the color of the subtitle ? Are subtitles defaulted to white ? Tks
  8. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    Did you try pressing the Subtitle/Subtitles button on your remote?
    May 2008
    Yes , I did that as well. No subs show. I finally gave up and redid the whole conversion process using the extracted srt sub and DVDFLICK . This worked like a charm.
