i'm converting .mov Quicktime files to .flv.
no matter how high i make the bitrate, the resulting file is 1.2MB and EXTREMELY choppy and pixelated.
the original is 31.1 MB. it's only 33 seconds.
No short answer here, sorry.
A constant bitrate is used by varying the quantizer values between Qmin and Qmax. Default values for FLV encodes with ffmpegX are Qmin=2 and Qmax=15. (See Options tab.) In general, lower quantizer values get higher quality output and higher quantizer values get lower quality output.
When you set the target video bitrate too high, every frame will be encoded at quantizer value Qmin. This will result in some output bitrate that may be lower than what you had set as target bitrate. ffmpeg just doesn't know what to use the remaining bytes for. It will not use it for extra quality, as it is already encoding at maximum quality (fixed at Qmin).From the ffmpegX website:
Sets the minimum quantizer. The quantizer is the compression level used to encode a frame. More compression means smaller filesize and less image quality. Complex frames will require more compression in order to fit in a constant bitrate, so the quantizer will vary within the qmin/qmax range in attempt to control the bitrate. Range is 1-31, though qmin=1 is not recommended. Setting qmin=qmax will lead to variable bitrate encoding.
Sets the maximum quantizer. Range is 1-31, recommended range is 10-31.
Did you have to use "Invert mapping" to get this clip to encode? That would be a known issue.Originally Posted by psmankikar
Did you upscale on playback, or play at the FLV's native resolution? Did you change the target video size (width and height in pixels) from the FLV preset (320x240)?Originally Posted by psmankikar
Pixelated video problem on PC
By blacksheepdownunder in forum Newbie / General discussionsReplies: 29Last Post: 25th Sep 2010, 22:51 -
Pixelated Video
By toadzky in forum Newbie / General discussionsReplies: 7Last Post: 7th Apr 2010, 03:28 -
Video background is pixelated
By RagingSloth in forum Newbie / General discussionsReplies: 27Last Post: 23rd Apr 2008, 11:04 -
Pixelated/blockish video
By rancid in forum Authoring (DVD)Replies: 5Last Post: 27th Feb 2008, 03:01 -
Captured video is very pixelated.
By otnpabka in forum Capturing and VCRReplies: 4Last Post: 24th Jul 2007, 15:02
