  1. Hello, I capture alot of Gameplay, mostly BF:BC2 atm(but also other games in the future).
    I used to capture with fraps but it just eats to much FPS in BF:BC2 for example.
    I found this http://www.blackmagic-design.com/products/intensity/ .
    Would this be possible: "Graphic Card --HDMI Cable---> Intensity Pro --HDMI Cable---> Monitor.
    I think this would be possible caus the intensity pro has a HDMI in and output.
    My System
    i7 860 @ 2.8GHz
    MSI P55-CD65
    Corsair 2x2GB DDRIII
    MSI 5850
    Asus Xonar DS
    1x Samsung F3 1TB
    1x WDS 320GB
    1x Samsung 200GB
    Oh yea, also, how much of strain would capturing for example BF:BC2(1920x1080, high settings prefered) be on my system, I've seen this picture about the required harddrive speed
    The 100-120MB/sec isnt to much of a problem with a 2x F3 in raid 0.
    But what about the CPU, memory and graphic's card?
    When playing BF:BC2 my memory/CPU gets used for ~50%.
  2. Your saying you want to play the game and record on the same computer? Ain't gonna happen.
  3. Yes I do, so i guess its way to heavy on my machine then : /
  4. If your graphics card has component video out you might be able to use a Hauppauge HD PVR to capture while you play. Just disable the capture programs video output. Then all your doing is saving a low bitrate USB video stream to a file while playing.
