Hey Guys, I have a Compaq CQ-61 and i was wondering if i could get a Hauppauge HD to work with no problems....?
Specs:
Base
Processor SupportIntel® Celeron® Processor
Intel® Pentium® processor
Intel® Core 2 Duo® processorChipsetRAM SizeUp to 8GBRAM Type800Mhz DDR2RAM Slots2
Storage
HDD Size160GB to 500GB - 5400RPMHDD TypeSATAHDD Bays1HDD Size2.5”Optical DriveDVD+-RW with Lightscribe
Input
Keyboard101 key compatible keyboardTouchPadYesTrack PointNo
Graphics
Screen15.6” 1366×768 WidescreenGraphics ControllerIntel Graphics Media Accelerator 4500MHD
ATI Radeon HD 4650Graphics Memory512MB - ATIGraphics Memory TypeShared - Intel
Dedicated - ATIVGA Out PortYesDVI Out PortNoHDMI Out PortYesDisplayPortNoTV Out PortNoTabletNo
Sound
Sound ControllerHigh Definition AudioSpeakers2MicrophoneYesHeadphone PortYesMicrophone PortYesLine In PortNoS/PDIF In PortNoS/PDIF Out PortNo
Network
Ethernet Port10/100/1000 EthernetWireless802.11b/g WLANBluetoothNoWWANNoUltra WideBandNoModemNo
Ports
USB Ports3 x USB2.0Firewire PortsNoExpressCard SlotNoPC Card SlotNoE-SATA PortYes, shared with one USB portSerial PortNoParallel PortNoDocking Station PortNoIRNo
Physical Details
Dimensions (W x D x H)37.8cm x 25.2cm x 4.37cmWeight2.75kg
Power
AC Power65 W AC Power AdapterBattery6-cell Lithium-Ion (Li-Ion) battery
Other Hardware
Card ReaderYes, 5-in-1WebcamYesTV TunerNoFingerprint ReaderNoSmartCardNoGPSNo
General specs like those aren't very helpful. For one thing, a specific processor type and speed isn't listed. If you can post a description of the exact hardware in the laptop you have or plan to buy, then maybe you will get an answer. Otherwise, nobody will be able to give you one.
Go to ARogan's WDTV review and download some of the sample files:
http://blog.arogan.com/2008/06/hauppauge-hd-pvr-model-1212.html
If you can view those smoothly your laptop can probably capture with the HD PVR. Try running MPCHC with its built in h.264 decoders. The Intel Graphics Media Accelerator 4500MHD has hardware AVC decoding so it will probably work.
What Laptop is adequate for editing with Hauppauge HD PVR?
By Quivox in forum Newbie / General discussionsReplies: 2Last Post: 9th Jan 2010, 18:26 -
Hauppauge HVR 2250 won't work with PCIE 2.0
By latichever in forum Capturing and VCRReplies: 1Last Post: 15th Sep 2009, 09:18 -
Work-Around For Poor Hauppauge HD-PVR Comb Filter?
By dublus in forum Capturing and VCRReplies: 9Last Post: 25th Aug 2009, 19:54 -
DVDs work in desktop PC but not in laptop - previously worked in laptop
By Brent Jewell in forum Newbie / General discussionsReplies: 3Last Post: 6th Nov 2008, 20:40 -
BUILDING HTPC To work with Hauppauge MediaMVP
By THE_oldguy in forum Media Center PC / MediaCentersReplies: 23Last Post: 29th Sep 2007, 23:25
