Heres my situation. I was recording something (fairly important) using a screen capture program. The problem is, the computer crashed and had to restart before I had a chance to save the file. I found an 856.2 MB AVI file in the "temp" directory of the screen capture program created at the same time that I was using it, so I know that that's the video. The problem is, I can't get it to play at all in any program. I'm assuming it's corrupted somehow due to not being saved properly, however I really need to repair the file and get it to play. Any ideas of how to do this would be greatly appreciated! Thank you!
Results 1 to 11 of 11
Try open with virtualdub and avidemux. And if it can read it save as a new avi(in virtualdub choose video->direct stream copy and audio-> direct stream copy).
Even with MediaInfo in Tree View?
It sounds like it probably doesn't have the AVI header (if the capture was interrupted, it probably didn't have a chance to write a proper header, or write the header at all). I'm not sure how to fix that, though.If cameras add ten pounds, why would people want to eat them? -
There is program called AVIpreview.. its old, but i still use it to make longer previews of emule temp files. It works for Divx, Xvid Codecs and variants.
Its a console program, so its not for the faint hearted people.
Looks like the original author doesnt have the page available anymore, but you can find it on net, Avipreview 0.85 Beta, or on this link http://www.brothersoft.com/avipreview-download-62511.htmlLast edited by Joltkola; 20th Feb 2010 at 16:06. Reason: Fixed the link
Corrupted/damaged video file .avi
By aizen in forum RestorationReplies: 8Last Post: 31st Jan 2012, 13:17 -
mp4 file corrupted. Very important file. Need some help!
By seanloughry in forum Newbie / General discussionsReplies: 2Last Post: 5th Dec 2011, 17:54 -
Large corrupted AVI file, what to do?!
By WaveofShadow in forum Software PlayingReplies: 12Last Post: 13th Sep 2010, 23:42 -
Corrupted AVI File. How Can I Play It?
By GangstaRap in forum Newbie / General discussionsReplies: 4Last Post: 8th Sep 2008, 16:23 -
corrupted dv file
By marshs in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 5th Aug 2008, 17:40
