i seem to be having troubles converting standard DV Avi files from AvidLiquid into divx:
I use one PC for editing in Avid Liquid, and another one with avisynth fopr encoding the resulting DV's into xvid
however, i am not able to open the dv files:
AviSource("e:\mertavi.avi")
i have cedocida loaded on this encoder pcCode:[*] AVI: Opening file "E:\omroep3.avs" [E] Error: Avisynth open failure: AviSource: Could not decompress frame 0 (E:\omroep3.avs, line 10)
Now when i get the same DV avi's from our studio they load fine with no errors
But i see a strange dv codec on the editPC called Pinnacle DV Codec that i am not able to remove(from avid liquid?)
when i search for Pinnacle DV Codec i get this:
http://www.free-codecs.com/download/Pinnacle_DV25_Codec.htm
when i install that codec on the encoding pc, the video loads again, but as written there, the colours are washed out etc
what am i doing wrong here?
Using the builtin dv decoder from virtualdub loads the DV also
without builtin:
Code:[*] Beginning preview operation. [i] Dub: Recompressing using format: XRGB8888.[*] Ending operation. [E] Error: VideoSourceAVI error: The source image format is not acceptable. (error code -2)
Results 1 to 1 of 1
MPEG2Enc encoding from VirtualDub
By Computer Nerd Kev in forum Capturing and VCRReplies: 6Last Post: 19th Jul 2011, 07:38 -
How to get Xvid encoding in VirtualDub
By Dr_Asik in forum Newbie / General discussionsReplies: 9Last Post: 25th Feb 2010, 10:31 -
re-encoding in VirtualDub?
By whatever911 in forum Video ConversionReplies: 6Last Post: 15th Feb 2009, 11:30 -
Help with 2-pass encoding and VirtualDub
By adkom in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2008, 10:41 -
Virtualdub WMV Encoding
By kidcash in forum Newbie / General discussionsReplies: 1Last Post: 18th Jan 2008, 03:47
