Results 1 to 25 of 25
  1. Hi I don’t know if anyone here can help me but I am using the above program to convert this .mpg movie to vob files such as as VIDEO_TS and AUDIO_TS to watch on a home DVD player but after its converted the quality is bad it was very sharp before, but now after its blotchy a bit like mosaic effect every so often. can someone suggest a fast program like ConvertXToDVD to make those same files VIDEO_TS and AUDIO_TS
    Please give more information about your source mpg. Resolution/frame size, runtime, etc.
    Oct 2007
    Check the setting on the "Encoding" page. Choose the "Auto" option, it will give the best possible output based on your input file. If your still not getting the results you want, try the freeware avstodvd or dvdflick, they probably won't be as quick but will give good results.
  4. sorry here is a gspot snap
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    It looks it's dvd compliant so need for reconversion. Author the mpg to a dvd -video with gui for dvd author(or dvd flick, be sure to choose to not reconvert when you import though) and burn on a dual layer DVDR with imgburn. Or author it, output on the HDD and then shrink the VIDEO_TS folder with dvdrebuilder or dvd shrink so it fits on a standard dvdr.
  6. Yes, as Baldrick says. The file is too big for a single layer DVD (because of the high bitrate) and that might be why the result from ConvertXtoDVD looked different, as it was shunk to fit,maybe.
  7. Originally Posted by Baldrick View Post
    Will dvdflick make the movie into a VIDEO_TS folder ready for dvdshrink then
  8. Member Bulldog57's Avatar
    Jan 2006
    Australia
    yes it will make the movie into VIDEO_TS and AUDIO_TS folder ready for dvdshrink
    Bulldog57
  9. ok thanks, but why is dvdflick so slow at converting slower than ConvertXToDVD isnt dvdflick the same then what ConvertXtoDVD does
    Aug 2004
    If you are using v4 of ConvertXtoDVD try HQ in encoding options and tick 2 pass encoding
  11. Originally Posted by ulapines View Post
    Where is HQ then in encoding options I can see where it says 2 pass encoding
    what difference will this make to movie then
    Aug 2004
    It tries to adapt the bitrate to fill the whole disk >4 GB
    Like this
    [Attachment 415 - Click to enlarge]
  13. Originally Posted by ulapines View Post
    Like this
    cant click on the attachment as it says this
    Invalid Attachment specified. If you followed a valid link, please notify the administrator
    Aug 2004
    Another try, if it doesnt work I give up
    [Attachment 418 - Click to enlarge]
    Aug 2004
    OK new rty
    Oct 2007
    Keep in mind that with Convertxtodvd, when you choose the encoding option, you are not telling convertxtodvd what to do with the output, you are telling it what you have for input. You do not choose "HQ" because you want High Quality output. That would be silly, why would anyone not choose that option LOL..... In other words if you choose "HQ High Quality up to 80 min" and you source file is 180 minutes then you will get worse results than if you choose LQ Low Quality. You best move is to choose "auto" and let the app check your source file duration, it will choose the best encoding profile for you.
    Aug 2004
    So you mean a low bitrate with LQ Low Quality gives better quality than a bitrate with HQ that fills up your DVD5 disk space?
  18. Member
    Oct 2007
    What I mean is if you have a source that is very long in time duration, you cannot expect to get good results so you would tell convertxtodvd to do a low quality encode and it will do a variable bitrate offering higher bitrate to the areas that need it (dark scened with lots of motion) and will offer less bitrate to the scenes that do not need it (well lit low or no motion)..... If you have a short duration source file, you can expect high quality results, so you tell convertx to do a high quality encode and it will do a constant bitrate encode offering the same bitrate to the entire video. The important thing to remember is to choose the encoding profile based on the source OR just use "auto" and this will all be chosen for you with the best choice. Don't worry about wether nor not the entire 4.7GB disk is filled, padding the bitrate to fill the disk just makes a bigger file that takes longer to encode, it is not giving you better quality.
    Why are you reconverting it again? Just author it.
    The source is PAL, too.
    Aug 2004
    My experience from ConvertXtoDVD is that if you choose low quality with a given duration of the movie you get a project size appr. half
    the size of same movie in high quality encoding. So one movie with 1hour 30 min duration in low quality encoding was appr. 2 GB in size
    whereas same movie in High quality was appr. 4 GB
    I also noticed that the movie with the bigger size looked better on my TV.
  21. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Personally, I think that VSO screwed the pooch with ConvertXtoDVD4. The changes they have made to the quality settings are at best unintuitive, and at worst, completely worthless. And regardless of the setting chosen, encodes are now consistently undersized. The same 2 hour 10 minute movie encoded using high quality mode in CXD3 fills a disc to 98%, while CXD4 produces 2.78GB using high quality, medium quality or auto. Two-pass encoding doesn't do anything to improve the space utilisation, or produce better quality than the single pass CXD3 encoding. In short, if you have CXD3 and are happy with it, don't upgrade to CXD4 until they get it working correctly. Very disappointing.
    Read my blog here.
  22. Member
    Aug 2004
    Found this on VSO forum:
    The common mistake is to believe that BIGGER SIZE / BITRATE will produce bigger quality. THIS IS NOT TRUE IN ANY CASE.
    Link:http://forums.vso-software.fr/how-to-get-best-quality-max-of-files-doesn-t-fill-dvd-t11326.html
  23. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    No, bigger is not always better, but squeezing 140 minutes into 2.7GB will not produce good quality either. The encodes from CXD3 that fill the disc are also demonstrably higher quality than the undersized encodes from CXD4.
    I have been using CXD since the DivxtoDVD days, so I understand how the product works, and VSO's arguments/rationalizations. I still think CXD3 is a good product for what it does, and the only one-click-wonder worth paying for. But my comparison testing between CXD3 and CXD4 so far lead me to state that I believe CXD4 to be a regressive step for the product line.
    Read my blog here.
  24. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    Yeah i was wondering that before i came to your post!!
    Reconvert it then transcode it
    JUST AUTHOR IT!!!!
    With an authoring program, then if you have to shrink it a tad then use dvdshrink or better yet DVDRebuilder.
    You are just degrading it more by converting it more than you need to.
