  1. I recently received files from a client.
    The files have a .mov extension but i get no picture in quicktime or media player. Only VLC is able to run it.
    I ran the file through GSpot and it tells me that the file has an hdv1 codec.
    My goal is to import these files to premiere cs4 to edit but i can’t even play them without vlc.
    Does anyone have any idea what to do?
    Maybe try mpeg streamclip and reconvert to another format but if quicktime wont read it might not work that well.
  3. Originally Posted by kobiv View Post
    My goal is to import these files to premiere cs4 to edit ...
    I'm not sure, but with Adobe DV Rack HD 2?
    Maybe with an additional decoder... Raylight Decoder or Calibrated{Q} DVCProHD Decode?
    BTW
    If VLC can play this file, then usually can convert too.
    VideoAudio.pl - Serwis o technologii wideo & audio
  4. I think ffdshow includes a hdv1 decoder.
  5. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    hdv1 is 720p 30. can you cut a sample and post it somewhere?
    the avid dnxhd quicktime codec [edit] sorry won't decode hdv1 [/edit]
    chrissyboy's makesample tool can cut just about anything.
  6. However... HDV1 it's MPEG-2 video (720p30) in QuickTime (.mov) container.
    So... I think is possible re-mux it to MPEG-TS (and maybe MPEG-PS) used FFmpeg or VLC.
