I wanted to no for the bst display settings for converting a avi to mpg using tmpec ver .a and panasonic converter.... especially to take THOSE DAM PIXELATION out of certain parts![]()
If you are formatting your mpeg for a vcd, the low resolution is probably to blame for loss of detail and pixelation. If you are referring to pixelation as in compression artifacts, try increasing the motion search precision under the "video" tab in the settings, although this will make encoding take 2-3x longer.
Questions regarding recording settings and compression settings
By so in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2011, 08:45 -
Best Settings
By devdev in forum DVD RippingReplies: 2Last Post: 26th Jan 2009, 10:46 -
HD Settings
By kiwikiwi in forum EditingReplies: 9Last Post: 13th Dec 2008, 16:20 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Settings to convert WMV to VCD/DVD-playable format?
By pingosimon in forum ffmpegX general discussionReplies: 5Last Post: 16th Jul 2007, 18:53
