hello all,
i decided i wanted to set up a home server so i could access files from school, etc.
I followed the steps on http://lifehacker.com/130806/how-to-set-up-a-home-ftp-server and it was finished successfully. I can access my home server via localhost.
my problem is I cant get to it through my ip address.
My internet connection is as follows: Modem -> vonage adapter -> belkin wireless router -> pc
I set up the vonage adapter to forward port 80 to the router, and i set up the router to forward port 80 to my pc, yet i still can not access it. any ideas?
Port 21 is the normal ftp port, but you can assign what ever port you want to it (420). Specify the outgoing port in your ftp software and match that port in your ftp program (ftp://192.168.1.1:420). Doubtful your ISP will allow incoming connections on most common ports. You can disable what firewalls you have and run a test at GRC to see which ports are open.
Linux _is_ user-friendly. It is not ignorant-friendly and idiot-friendly. -
If in doubt, Google it.
from my understanding a home server is different from ftp. i am not even using an ftp client, just accessing the server via web browser. you cannot upload files to this server.
edit: either way opening up 21 didn't work =\
edit2: but i'm definitely doing something wrong because that grc website reports on port 80 AND 21
Your system has achieved a perfect "TruStealth" rating. Not a single packet — solicited or otherwise — was received from your system as a result of our security probing tests. Your system ignored and refused to reply to repeated Pings (ICMP Echo Requests). From the standpoint of the passing probes of any hacker, this machine does not exist on the Internet. Some questionable personal security systems expose their users by attempting to "counter-probe the prober", thus revealing themselves. But your system wisely remained silent in every way. Very nice.Last edited by gooberguy; 17th Feb 2010 at 07:13.
ISPs can't block too many ports -- the Internet is bigger than web, email and FTP.
Home server/Networked HDD
By OverrRyde in forum Newbie / General discussionsReplies: 16Last Post: 14th Jun 2011, 20:08 -
Panasonic SC-PT150 - Home Theater - Video Playback through USB Port
By muneeb.ansari in forum Video ConversionReplies: 1Last Post: 11th Mar 2009, 06:43 -
Need advice on setting up a home media server
By jamietallman in forum Video Streaming DownloadingReplies: 2Last Post: 7th Jan 2009, 00:25 -
Home Media Server
By muehleis in forum DVD RippingReplies: 2Last Post: 14th Aug 2008, 14:53 -
port forwarding and static/dynamic IP address
By Rudyard in forum ComputerReplies: 3Last Post: 21st Jan 2008, 16:53
