Hello,
I installed the latest demo version of this software. It works fine on files I convert from dvr-ms to mpg. If I try to add a dvr-ms file, I receive the error "ffmpeg.exe has stopped working". I have uninstalled the software and reinstalled it in the C drive but not in program files as this is mentioned in other posts with the same results. I read another post where chrissyboy provides instructions to be ran at a command prompt. Here are the results:
FFmpeg version SVN-r7159, Copyright (c) 2000-2006 Fabrice Bellard, et al.
configuration: --enable-memalign-hack --disable-debug --enable-pthreads --ena
ble-a52 --enable-gpl --enable-dts --enable-faad --enable-avisynth
libavutil version: 49.1.0
libavcodec version: 51.27.0
libavformat version: 51.12.1
built on Sep 17 2007 14:54:50, gcc: 4.3.0 20061204 (experimental)
Input #0, asf, from 'C:\Users\Public\Recorded TV\No Commercial\Lost_KSTPDT_02_02
_2010_18_58_01.dvr-ms':
Duration: 00:28:35.4, start: 0.000000, bitrate: 20384 kb/s
Stream #0.0: Invalid Codec type -1
Stream #0.1: Audio: 0x0000, 48000 Hz, stereo, 383 kb/s
Stream #0.2: Video: mpeg2video, yuv420p, 1280x720, 20000 kb/s, 59.94 fps(r)
Must supply at least one output file
=================== AV Details ===================
file=C:\Users\Public\Recorded TV\No Commercial\Lost_KSTPDT_02_02_2010_18_58_01.d
vr-ms
FormatName=asf
Num_Frames=102823
DurationInSecs=1715
Duration=00:28:35.4
VideoCodec=mpeg2video
VideoFFSTNum=2
Width=1280
Height=720
Standard=NTSC (59.94fps)
BitRate=20384
AudioStreamCount=1
Audio1FFSTNum=1
Audio1StreamID=[0x2]
Audio1SampleRate=48000
According to the release notes, this is supposed to work with dvr-ms files.
Thanks for your help!
An update. I purchased the software even if I had to do the extra step of converting the recorded TV DVR-MS to MPG. Not really that big of a deal as I was already using DVRMS Toolbox to remove the commercials anyway. So I purchased the software and installed it. As a test I selected a dvr-ms file and there was no error. But then I noticed there was no audio (see other post) in the preview so thought I had a different issue. I need to confirm this with a true test but I believe the error went away using the non-demo version of the software.
Thanks for the update
Svcd2dvd stopped working
By H4MST3R in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 12th Apr 2011, 21:53 -
SVCD2DVD Stopped Working
By magic90 in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 28th Sep 2010, 07:07 -
ffmpeg.exe has stopped working error when trying to add asset
By skeet09 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 27th Oct 2009, 15:15 -
DVD Flick error message "ffmpeg.exe has stopped working"
By stewiegriffin711 in forum Authoring (DVD)Replies: 4Last Post: 17th Aug 2008, 07:20 -
WMP stopped working?
By glowworm12 in forum ComputerReplies: 5Last Post: 22nd Feb 2008, 08:44
