Hi all,
I'm new in this forum and I need your help !
I have the following problem :
I "backuped" a DVD with Smartripper to my disk.
Then I use DVD2AVI.
Then I use TMPGEnc to create a VCD (sorry but my DVD player can't handle SVCD)
My question is now : how can I select the language ?
With DVDx I can select German or English (I don't use it anymore cause the quality was very bad) - but how can I select the language with TMPGEnc ???
THX for any help !!!!!!!!!!!!!!!!!!!!!!!!
cheers
Degdus![]()
select the audio track in dvd2avi under audio/track number/#. the stream processing tab in smartripper will help you identify the one you want(first audio stream is track 1)
Convert DVD with choice of audio language and burned-in subtitle language
By theproof in forum DVD RippingReplies: 2Last Post: 24th Jun 2010, 17:34 -
Guide Needed for Authoring Multi Language DVD with multi language menus
By kemimich in forum Authoring (DVD)Replies: 2Last Post: 24th Dec 2008, 16:46 -
Authoring Multiple Language DVD with multiple language menu options
By kemimich in forum Authoring (DVD)Replies: 7Last Post: 8th Sep 2008, 16:29 -
changing language
By integboi in forum Newbie / General discussionsReplies: 5Last Post: 14th Jul 2008, 01:19 -
language barrier
By romanticwarrior in forum Authoring (DVD)Replies: 3Last Post: 26th Jul 2007, 14:41
