Hello All,
Long time reader, first time writer. Thanks for the help in the past. Anyway...
I converted a bunch of files using Handbrake (CLI) to mp4's using the iPhone preset. A few of these videos are now playing back at 1/3 speed. What is the simplest (free) tool to change these videos to 300% speed?
-- Zelman
I tried using MPlayer, windows media player, and my Xbox. All played super slow. Here is the mediainfo output:
Code:General Complete name : I:\Movies\Inglourious Basterds.mp4~convert.mp4 Format : MPEG-4 Format profile : Base Media / Version 2 Codec ID : mp42 File size : 846 MiB Duration : 7h 38mn Overall bit rate : 258 Kbps Encoded date : UTC 2010-01-09 23:51:05 Tagged date : UTC 2010-01-10 00:18:34 Writing application : HandBrake 0.9.4 2009112300 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : Baseline@L1.3 Format settings, CABAC : No Format settings, ReFrames : 2 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 2h 32mn Bit rate mode : Variable Bit rate : 382 Kbps Width : 480 pixels Height : 208 pixels Display aspect ratio : 2.35:1 Frame rate mode : Variable Frame rate : 23.976 fps Minimum frame rate : 7.992 fps Maximum frame rate : 23.981 fps Resolution : 8 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.160 Stream size : 418 MiB (49%) Writing library : x264 core 79 Encoding settings : cabac=0 / ref=2 / deblock=1:0:0 / analyse=0x1:0x111 / me=umh / subme=6 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=12 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=0 / wpredp=0 / keyint=240 / keyint_min=24 / scenecut=40 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00 Encoded date : UTC 2010-01-09 23:51:05 Tagged date : UTC 2010-01-10 00:18:32 Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177 Transfer characteristics : BT.709-5, BT.1361 Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177 Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format version : Version 4 Format profile : LC Format settings, SBR : No Codec ID : 40 Duration : 7h 38mn Bit rate mode : Variable Bit rate : 128 Kbps Maximum bit rate : 205 Kbps Channel(s) : 2 channels Channel positions : L R Sampling rate : 48.0 KHz Stream size : 420 MiB (50%) Encoded date : UTC 2010-01-09 23:51:05 Tagged date : UTC 2010-01-10 00:18:34 Text ID : 3 Format : Apple text Codec ID : text Duration : 2h 32mn Bit rate : 0 Stream size : 14.0 Bytes (0%) Encoded date : UTC 2010-01-09 23:51:05 Tagged date : UTC 2010-01-10 00:18:34
It looks like the video header and the text header have the correct length, but the others are off. Any idea how to make them all agree?
Handbrake double speed playback question.
By daz1976 in forum Video ConversionReplies: 3Last Post: 31st Aug 2011, 12:17 -
Converted videos display issues
By thumpy in forum Video ConversionReplies: 6Last Post: 20th Apr 2010, 14:40 -
Videos converted skip and are cut off
By gdreger in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 28th Dec 2009, 16:12 -
File Converted by Handbrake (0.9.3) Using iPod Preset Won't Play on iPod
By GrayStrickland in forum Video ConversionReplies: 0Last Post: 8th Mar 2009, 21:56 -
Need help fixing up already converted DVDs of old videos
By t_burrito in forum RestorationReplies: 1Last Post: 10th Jun 2007, 01:32
