    Jun 2009
    I am trying to rip a movie with tsmuxer ive done a few of them before and had gotten the hang of it. i have anydvd to remove encryption and i use tsmuxer so i can rip just the main movie with 1 audio file and subtitles. the movie i am trying to rip is UP. it cuts off about a good 20 mins or so in the begining. any ideas why? thanks (=
    Are you opening the mpls playlist in tsmuxer? If not then use bdinfo to see what playlist file to open in tsmuxer. Read https://forum.videohelp.com/threads/309479-Blu-Ray-to-MKV-with-optioinal-multi-language...btitle-support
  3. Member wulf109's Avatar
    Jul 2002
    Most BR movies are in one file but some use multiple m2ts files. Baldick is correct you need to open the mpls file to get the whole movie. BDinfo will list all the stream info allowing you to open the correct mpls file.
    Jun 2009
    ok guys thanks for fast response and ill give that a try usually this is how i do it... i open (br drive):\bdmv\stream\*.m2ts i open the largest one. but again thanks a ton!
    Jun 2009
    Hey Baldrick that link u sent me doesnt work any longer i get a missing page?
    Jun 2009
    thank you sir
