My DVD burner is on its last legs, apparently.
If I insert a disc, software does not recognise it unless I atttempt a "load" several times.
When it does, it works fine, reading and writing. Never a bad burn yet.
So I'll be shopping for a new drive next I get into town, but in the meantime, is there any software that can keep attempting to load a DVD, or a command line that can be scripted to do so, so I don't have to keep clicking the button over and over till it works?
Results 1 to 12 of 12
Not that I'm aware of, but I suppose you could write some sort of script. Maybe someone here would have an idea for that.
You may run into another problem, though. If an optical drive fails to read a disc six consecutive times, the OS may revert the drive to PIO mode and your reads and writes will be very slow, along with high CPU usage. You might want to check the DMA/PIO status of that drive on occasion. That's generally a problem with PATA drives. I'm not sure if SATA drives share the same problem. -
I've had this problem for a while, was several retries now its dozens.
However, when it does finally read then it burns at full speed as normal, so that's not a problem.
Also, I use Win2k, and I don't think that does the fallback, it appears to be in DMA mode in Device Manager anyway. -
Since when doesnt win2k revert back to PIO mode in case of transfer errors??
*** Now that you have read me, do some other things. *** -
Presumably until it recognises a disc is present, there are no "errors" as far as Windows is concerned. In any case, it's still and always has been in DMA mode.
Do you actually have anything useful to say, or were you just looking through old posts to find someone to smirk at?Last edited by AlanHK; 21st Feb 2010 at 11:42.
chef's next post will be at 08/05/2010.
Possible time = 03:41:15 [ possible calculation's mistake (+ or -) 5 secs].Last edited by chrchr; 17th Apr 2010 at 04:59.
Please keep this thread civil and on topic or it will be locked.
Moderator redwudz
My DVD Authoring software stopped working and had an "APPCRASH" error
By Blueknight in forum Newbie / General discussionsReplies: 6Last Post: 13th Jul 2011, 22:55 -
best software to make "fair use" backups of DVDs to DVD +/-R?
By gastrof in forum DVD RippingReplies: 4Last Post: 14th Jun 2011, 14:27 -
I get a "could not load codec settings" with Fairuse Wizard
By felix in forum DVD RippingReplies: 3Last Post: 29th Apr 2011, 11:10 -
Samsung R155 DVD Recorder - "Recorded" or "Blank"?
By mhamini in forum DVD & Blu-ray RecordersReplies: 3Last Post: 6th Feb 2010, 19:01 -
Cant Play / Load A RAW DV file "Codec Status Undetermined" Please
By hypnoticpimp in forum Newbie / General discussionsReplies: 4Last Post: 30th Mar 2009, 14:29
