If a mkv fail audio codec is 5.1 dts. Can I rip the dts audio as dts to insert to dvdlab? Can I shrink a blue ray disc to fit a 4.7g dvd? Thank you.
DVD Lab can only author DVDs, so the assets must be DVD compliant. DTS is DVD compliant only if it is 768 kbps, not HD DTS at 1536 kbps, so you would have to re-encode the audio.
If you have a PS3 or a bluray player that can play AVC HD format discs then you can use Multi-AVCHD or AVCHDCoder to create AVC HD format files that will fit on a single or dual layer DVD blank.
Otherwise use AVStoDVD or ConvertXtoDVD to create a DVD from the file.Read my blog here.
Not exactly true: DTS @1536 kbps is DVD compliant too (http://en.wikipedia.org/wiki/DVD-Video#Audio_data).
Everything else is OK
Bye
Blueray player with mkv, xvid, divx, avi, etc... support. Advice please!
By szabo_77 in forum DVD & Blu-ray PlayersReplies: 34Last Post: 10th Feb 2016, 11:54 -
BlueRay to MKV,Why?
By wulf109 in forum Blu-ray RippingReplies: 3Last Post: 23rd Apr 2010, 03:30 -
Ripping Blueray to MKV
By unknownuser in forum Blu-ray RippingReplies: 2Last Post: 27th Sep 2009, 17:14 -
mkv to blueray on dvd 5
By Greg6721 in forum Authoring (Blu-ray)Replies: 3Last Post: 25th Jan 2009, 11:40 -
MKV to blueray
By NormaJ in forum Video ConversionReplies: 6Last Post: 31st Dec 2008, 12:43
