I'm trying to convert MKV files to mp4, avi, etc... so I can playing on my Ps3, dvd player, or Xbox. I tried differents software and some conversions were quick while others were fast even thouhgt the files were bigger. My problem is that some of these Mkv files that I try to convert tend to have the audio way out of sync, most of the time the audio is behind the movie by more than 10 seconds. No matter what type of file I tried to convert it to it always happens. Can anyone point me to what software I should be using or how can I fix this audio out of sync issue?
here is one of the videos I'm trying to convert:
Format : Matroska
File size : 230 MiB
Duration : 24mn 55s
Overall bit rate : 1 292 Kbps
Encoded date : UTC 2007-04-05 03:50:48
Writing application : mkvmerge v1.6.5 ('Watcher Of The Skies') built on Dec 7 2005 18:53:53
Writing library : libebml v0.7.6 + libmatroska v0.8.0
Video
Format : AVC
Format profile : High@L5.1
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Muxing mode : Container profile=Unknown@5.1
Codec ID : V_MPEG4/ISO/AVC
Duration : 24mn 54s
Bit rate : 1 138 Kbps
Nominal bit rate : 1 364 Kbps
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate : 29.970 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.124
Stream size : 203 MiB (88%)
Title : It's A Family Affair 2 (h264)
Writing library : x264 core 46 svn-504
Encoding settings : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=5 / brdo=0 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / chroma_qp_offset=0 / slices=1 / nr=0 / decimate=1 / bframes=2 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=2 / wpredb=1 / bime=0 / keyint=250 / keyint_min=25 / scenecut=40 / rc=2pass / bitrate=1364 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30
Language : Japanese
Audio
Format : Vorbis
Format settings, Floor : 1
Codec ID : A_VORBIS
Duration : 24mn 55s
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 22.8 MiB (10%)
Writing library : libVorbis 1.0.1 (UTC 2003-09-09)
Language : Japanese
Text
Format : ASS
Codec ID : S_TEXT/ASS
Codec ID/Info : Advanced Sub Station Alpha
Title : ass
Language : English
I have been using mkv2vob, xvid4psp 5, XenonMKV, and Super.
How to select audio channel when converting MKV files ?
By vcd_user in forum Video ConversionReplies: 1Last Post: 23rd Aug 2010, 17:48 -
converting newer mkv files w/ subtitles
By Dolly in forum MacReplies: 4Last Post: 26th Jul 2009, 16:52 -
converting MKV files in .avi container to dvd
By jamerican in forum MacReplies: 1Last Post: 27th Jan 2009, 11:29 -
Converting mkv files for the 360 - what am I doing wrong
By adam zapple in forum Video ConversionReplies: 3Last Post: 24th Nov 2008, 10:34 -
Help converting .mkv files.
By hellfire45 in forum Video ConversionReplies: 21Last Post: 7th Nov 2008, 22:22
