I burned several .mpg files onto a DVD using Burnaware Free. They play great on the computer from the DVD. But they wont play any audio on my Samsung DVD player. Video looks great, just no audio.
Any Ideas?
Thanks, Ken
Results 1 to 10 of 10
the audio should be dolby digital. It's probably mpeg-2 audio. higher end authoring applications will encode the audio to dd for you but otherwis you have to seperate the audio stream from the video and compress it to dd. There are some freeware utilities that will do the dd compression for you but they escape me right now..someone will come along to assist
I used Any Video Converter to make the file. It lists ac3 as the audio codec. I have other choices of mp2 or aac for the codec.
Any idea if those will work? -
Sure ... but do you really want to "re-encode" the video when simple demuxing and re-encode audio would be best
http://dvdauthor.sourceforge.net/ states the following:
"AC3 and raw PCM are the only two audio formats guaranteed to be supported by every DVD player.
North American DVD players may or may not support mpeg 1 layer 2 audio"
Mods, et. al.: Chime in on this - I believe the info that I have is correct.
Otherwise, why have I spent all the time converting audio to AC3? Even when I author with TDA I select AC3 output.Last edited by classfour; 16th Feb 2010 at 09:32.
;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
Most DVD players don't support ac3 for file playback,only DVD playback. It's true that mp2 is not officially supported by the NTSC DVD spec,it is supported by the PAL spec. Since the vast majority of DVD players are sold world wide most will support mp2 audio. Why not convert your mpg files to DVD.
OK, first of all we need to know what format we are dealing with here. Saying that you made a DVD means nothing. Some people say that when they burn data discs. Put the DVD in a PC and look at the contents. Do you see directories named AUDIO_TS and VIDEO_TS? Does the VIDEO_TS directory have a bunch of VOB, IFO and BUP files in it? If not, you don't have a DVD and that may be part of the problem.
WRONG! AC3 is valid on all DVDs and all DVD players MUST support it - no exceptions. -
jman98 ---- thanks for posting ........
(kept my blood pressure from hitting the ceiling) -
jman - thanks for the update. I knew there was a reason that I've paid extra for software to work with AC3 audio all these years.
MPG files won't play - Windows Media Player 11
By crjackson in forum Software PlayingReplies: 9Last Post: 9th May 2010, 20:16 -
Video DVD that doesnt play audio on DVDplayer but plays fine on computer ?
By hiavi in forum Video ConversionReplies: 6Last Post: 15th Jan 2009, 14:01 -
DVD Does not Play in Drve, But plays fine in Player
By HellSaber in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Feb 2008, 16:13 -
Some XviDs play choppy on standalone DVD player, but absolutely fine on PC
By udaykhan in forum DVD RippingReplies: 5Last Post: 15th Jan 2008, 11:09 -
converted vob files play on computer fine..skip when burned to dvd
By cduval04 in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2007, 18:26
