  1. Hi folks,
    I'm using a demuxing software to extract individually my video and audio file. The movie is Shawshank redemption which length is around 2 hours and 22 minutes. After, i demuxed the video and the audio, the output video file is 1h:45 minutes long. How is that possible ? Thanks for the your help
    Jon
    canada
    Either the file is corrupt or the media player is showing the wrong play time with the video part,use mediainfo to check it.
  3. Thanks. I want to add another track in muxman. It's my own track it's a wav file but it doesn't show on the muxman command. Any advice
  4. The Muxman command? What's that? Anyway, is this WAV file 48kHz? Does the Muxman log explain any error messages?
  5. Thanks Guys!! I found what i was looking for!
