  1. Hello. I heard from my friend that this forum can solve all kinds of problem. So i decided to approach u guyz for help.
    I have a subtitle file which might be corrupted. Althought it works when i use the subtitle file with VLC player, i cant get the subtitle file to work on my dvd player
    Could some1 here plz check whats wrong with the subtitle file which ive attached. Thanks in advance!
    canada
    Load the sub in SubtitleEdit and use tools/fix common errors and see if that helps.
    Feb 2008
    Twin Peaks
    Just a thought, but the name of the sub file needs to be the same as the name of the avi file and in the same folder. Is the name of the avi file Hindi sub.avi?
