So I'm using the ctrl+drag clip method to vary the speed of my clips (since I need the audio to match), but is there a way to reset a specific clip to tis default speed? I've tried dragging it back to its original length-ish, but the waves indicating the clip has been sped-up/slowed-down never disappear, so I can't get it exactly right.
Is there a better way?
ctrl+z to undo
or
right click the clip in the timeline, and enter the playback rate value -
Sony Vegas render template for clip on PC monitor
By mltwitz in forum Authoring (DVD)Replies: 2Last Post: 23rd Aug 2011, 15:17 -
Sony vegas 10 clip wont reverse!!
By Domiel in forum EditingReplies: 21Last Post: 21st Nov 2010, 18:39 -
Sony Vegas 8.0, trouble viewing video clip
By ir0n_ma1den in forum EditingReplies: 8Last Post: 10th Jun 2009, 21:36 -
how to increase/decrease and move a mask on a clip around(sony vegas)
By bojadada in forum EditingReplies: 4Last Post: 22nd Oct 2008, 23:38 -
How edit a clip to play @ 1/2 speed (slow motion) in Vegas 8 plt.
By Jensen in forum EditingReplies: 7Last Post: 12th Feb 2008, 13:23
