Hello!
I am trying to convert Real Media videos and got the hint to try it with ffmpegX. I installed ffmpegX the way it should be, renamed my harddisk from "Macintosh HD" to "Mac" and when I am using ffmpegX and open a .RM file and click on "Play" the video starts. Therefore I think the codecs and so on are installed correctly.
But when I try to convert such a video I receive immediately a "ding" sound. The log file looks like this:
Since I've renamed my harddisk to "Mac" (without quotation marks) and the filename of the sourcefile is even DOS-compatible I don't know what I else can do to let ffmpexX convert my videos./bin/sh: -c: line 0: syntax error near unexpected token `('
/bin/sh: -c: line 0: `printf "Encoding started on " && date && '/Library/Application Support/ffmpegX/mencoder' /test.rm -ovc x264 -nosound -ni -sws 0 -x264encopts threads=2:me=2:bitrate=940:qp_min=22:qp_max=51:i4x 4:keyint=120:nocabac:deblock:nob_adapt -ofps NTSC FILM (29.97) -vop scale=320:176,pp=0x33,harddup -of rawvideo -o /test.rm.ff.avi.264 && /Applications/ffmpegX.app//Contents/Resources/movtowav -o /test.rm.ff.avi.wav /test.rm && /Applications/ffmpegX.app//Contents/Resources/normalize /test.rm.ff.avi.wav && /Applications/ffmpegX.app//Contents/Resources/ffmpeg -i /test.rm.ff.avi.264 -i /test.rm.ff.avi.wav -y -vn -f mp4 -acodec aac -ab 128 -ar 48000 -ac 2 -map 1.0:0.0 /test.rm.ff.avi.aac.mp4 && /Applications/ffmpegX.app//Contents/Resources/mp4box -fps NTSC FILM (29.97) -add /test.rm.ff.avi.264 -add /test.rm.ff.avi.aac.mp4 -new /test.rm.ff.avi.mp4 && rm /test.rm.ff.avi.wav && rm /test.rm.ff.avi.264 && rm /test.rm.ff.avi.aac.mp4 && printf "Encoding completed on " && date && printf "\a"'
Do you have any suggestions?
The error is: syntax error near unexpected token `(', which refers to -ofps NTSC FILM (29.97).
The problem is that there is no such thing as "NTSC FILM (29.97)", hence the syntax error. There is "NTSC (29.97)" and "NTSC FILM (23.976)", however.
Verify that the target framerate is set to a valid value. Use the framerate drop-down menu in the Video tab for this. My advise would be to match the source file framerate.
No output: /bin/sh: -c: line 0: syntax error near unexpected token `('
By marmi in forum ffmpegX general discussionReplies: 4Last Post: 16th Jan 2011, 09:14 -
Media player Classic won't let me "navigate" using mkv files
By FatalX in forum Software PlayingReplies: 0Last Post: 20th Jul 2010, 20:51 -
"if" syntax error
By njitram2000 in forum Authoring (DVD)Replies: 2Last Post: 8th Nov 2009, 11:30 -
ffmpegX > what means error message "DIV16_KEY"?
By infopartner in forum ffmpegX general discussionReplies: 1Last Post: 29th Jan 2008, 15:09 -
avi.NET and "Unexpected Error"
By denali in forum DVD RippingReplies: 1Last Post: 12th Oct 2007, 16:01
