I have some videos I captured from my Pentax and when I load them into Premiere CS4, I get audio and no video. So I found a tip that if I used the xvid FourCC changer tool, it would make a few changes so that I could read the video.
OOPS!
Now the video file is intact, but nothing seems to be able to read it. In Windows explorer I can still see the length, dimensions, frame rate, etc. But it just won't play. This was supposed to alter the Codec settings.
Stupid me forgot to backup the file.
I downloaded SUPER, AVS4YOU and many other tools, but am at a loss. Even the FourCC tool says the file is not recognized. Is there anything I can do for this to get it back?
File truncated in the "legacy index" area.
· 95.1 KB (97,464 bytes) are missing
Multipart OpenDML AVI (2 parts)
(24810 frames in first part, 0 frames follow) -
fourcc changers don't alter the video, only the header (metadata)
Your video probably was damaged before you used it, I doubt there is much you can do to "fix" it
Try opening in vdub, checkmark the ask for extended options box in the open file dialog box, then checkmark rederive keyframes flags. Use direct stream copy for video & audio & resave it
If this is from a "point and shoot" type picture camera, chance are it was using mjpg for compression; if that's the case, all you needed to do was install ffdshow and enable the mjpg option in the vfw configuration and it should open in premiere pro
You can check with another clip to be sure (use mediainfo or gspot) -
hehehe... Four little letters.
Changed XVID to MJPG in the hex and it worked just fine!
Thanks!
Seeking for some easy tool to convert camera video to x264
By junglemike in forum Newbie / General discussionsReplies: 2Last Post: 9th Jun 2009, 06:03 -
AVI to DVD fourCC xvid question
By rockonvidtrade in forum Authoring (DVD)Replies: 7Last Post: 23rd Feb 2009, 11:29 -
FOURCC Change
By anirban in forum Newbie / General discussionsReplies: 7Last Post: 3rd Nov 2008, 20:35 -
Bad fourcc?
By louv68 in forum Video ConversionReplies: 1Last Post: 12th Mar 2008, 23:04 -
Fourcc descriptor
By gtwibell in forum ffmpegX general discussionReplies: 0Last Post: 26th Feb 2008, 03:52
