I love to make screen caps of videos to put on dvd using avstodvd. I use frameshots to do the screen caps. But for some reason frameshots will not accept mkv videos to do screen caps. Other types videos it opens without a issue like avi. I not sure if i tried to make mkvs screen caps back then on vista. Frameshots owner who i wrote to saids to install cccp codec pack. I know all about codec packs how they can mess up the computer. The mkvs i got play great using vlc media player. I have codec packs installed i never use them. Does anyone have any info that may help me out? I was gonna convert them to mpeg to make screen caps. But that would be a pain. I am using windows 7 I was not sure where to post this so if its in the wrong place a mod can move it.
Take the screenshot directly in vlc?
Does the mkv play in windows media player? If not then will frameshots not work. You basically just need ffdshow to play mkvs. No codec packs. -
I did try to make screen caps with vlc but it makes them to small and plus it would take me a long time to make screen caps from one video. I plays great in windows media player. I do have ffdshow installed from something else.
Open ffdshow config screen without opening a movie
By F u r u y á in forum Newbie / General discussionsReplies: 6Last Post: 7th Apr 2013, 05:15 -
A way to auto-make screen caps from videos?
By Scav2003 in forum MacReplies: 15Last Post: 20th Aug 2010, 01:05 -
Whats the best software to use to produce Screen Caps/Grabs ?
By maduncledai in forum Newbie / General discussionsReplies: 10Last Post: 26th Oct 2009, 20:38 -
VirtualDubMod crashed on me while opening an MKV file
By The Monarch in forum Newbie / General discussionsReplies: 2Last Post: 5th Oct 2009, 07:57 -
Capture JPEG Screen Caps From DVD
By philly33flyers in forum DVD RippingReplies: 10Last Post: 25th Aug 2007, 12:48
