    Jun 2009
    Israel
    hi
    in premiere cs3
    when im importing any file (beside uncompressed MPG files)
    most of the times he work smooth , if its not HD format
    until the part im adding effects and then the chapter i added the effects get stuck and not working smoth
    until i rendering this chapter. and it waste too much time that i have to render every section im adding effect
    in compressed files like avi wmv mov etc..
    and in HD files its working like hell
    because the renderings takes much longer than the regular AVI DV files
    and my computer got the requirements that cs3 needs in HD files and ofcourse also in avi dv files
    so what can i do about it?
    and if i have to convert it to uncompressed format which converter do u recommand?
    cheers
    eli
  2. Member Soopafresh's Avatar
    Jan 2004
    What CPU is in your computer? How much RAM do you have?
    Huffyuv is a lossless codec and will be faster, but if your CPU is slow it won't make much of a difference.
    "Quality is cool, but don't forget... Content is King!"
    Jun 2009
    Israel
    Pentium(R )Dual-Core CPU
    E 5200 @2.50GHz
    3.50GB of RAM
    is that good? or maybe i need quad?
    and how am i using this huffyuv
    10x
    Jun 2009
    Israel
    anyone pls?
    Jun 2009
    Israel
    that post is for hd editing files. and its nice, thank you very much, i'll adopt it.
    but im looking for something that will increse speed for AVI / DV files
    because my project is DV - PAL
    i've downloaded this Huffyuv codec and installed it
    how am i using it in premiere?
    Jun 2009
    Israel
    well they are talking there about which best codec should be used in premiere to get best resault
    but i asked how can i use it in premiere after i installed that the when im rendering it will use Huffyuv
    where to go in cs3 and what to do?
    cheers
    eli
