Hi
I can't find a tutorial that tells you how to convert DivX To X(S)VCD! The "how to convert DivX to SVCD" doesn't tell you how to make it a X(S)VCD. Am I missing something?
Thanks in advanced
CheerZ!![]()
First do some search about xsvcd and xvcd. And then you could download some xvcd or xsvcds tmpgenc templates as they includes some guides.
Actually, this one is pretty darn easy. Install TMPeg and just
use the project wizard.
1. Select the type of project (NTSC Film) usuallyfor me, <Next>
2. Select the input file (your divx file), <Next>
3. Select the source range (I usually put divx movies on 2 SVCDs) <Next>
4. Adjust the bitrate so that it fits under 740 MEG. I've had DVD drives
which have problems with SVCDs longer than this
5. Pick your output filename and you're off.
After that, just follow the VCDEasy authoring instructions in the other
guides and should be OK. -
Ugh. This cold is just killin me. I missed the X part.
I do have a question for you, though. Why do you want
x(s)vcds? Do you have a player which plays those and not divx?
How to convert WMP v9 (VC-1 Simple/Main) to divx/avi?
By ericdunn in forum Newbie / General discussionsReplies: 12Last Post: 28th Apr 2012, 17:09 -
Simple DVD to DIVX with quad core support?
By jarrodl in forum DVD RippingReplies: 2Last Post: 27th Aug 2009, 16:36 -
Simple DivX: Crashes with Mencoder Error Every Time
By CobraPilot in forum DVD RippingReplies: 5Last Post: 10th Jul 2008, 19:47 -
AviAddXSubs simple question (hopefully!)
By vladman2nd in forum SubtitleReplies: 1Last Post: 8th Jul 2008, 01:01 -
Simple Mplayer Question
By Maikeru-sama in forum Newbie / General discussionsReplies: 6Last Post: 29th May 2008, 21:10
