Hi
I am using Sunplus PMP Transcoding software to convert video files into ASF format.
This software not support some formats like : MKV , FLV , ....
I try some software like SUPER and ImToo MPEG Encoder and AVS video converter but the output files not play in my Zling Studio Portable Media Player.
The output file of sunplus PM Transcoding software have below setting and play in my Zling Studio PMP:
General
Format : Windows Media
File size : 39.8 MiB
Duration : 4mn 18s
Overall bit rate : 1 294 Kbps
Maximum Overall bit rate : 1 064 Kbps
Encoded date : UTC 1970-01-01 00:00:00.000
Video
Format : MPEG-4 Visual
Codec ID : DIVX
Codec ID/Info : Project Mayo
Codec ID/Hint : DivX 4
Description of the codec : DIVX4
Duration : 4mn 18s
Bit rate : 850 Kbps
Width : 352 pixels
Height : 240 pixels
Display aspect ratio : 1.467
Frame rate : 25.000 fps
Resolution : 8 bits
Bits/(Pixel*Frame) : 0.402
Stream size : 26.2 MiB (66%)
Audio
Format : ADPCM
Codec ID : 11
Codec ID/Hint : Intel
Description of the codec : IMA_ADPCM
Duration : 4mn 18s
Bit rate : 384 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Resolution : 4 bits
Stream size : 11.8 MiB (30%)
please refer me to a software which have same output result with support of MKV and FLV and ....
Thanks.
Results 1 to 1 of 1
need help converting .asf to h264 .mp4
By hydra3333 in forum Video ConversionReplies: 3Last Post: 12th Sep 2010, 07:53 -
Optional second audio
By Psymon007 in forum Newbie / General discussionsReplies: 4Last Post: 9th Jun 2009, 16:42 -
converting asf to avi
By projecttemp in forum Video ConversionReplies: 2Last Post: 3rd Aug 2008, 08:40 -
converting asf to avi problem
By konig in forum Video ConversionReplies: 1Last Post: 6th Mar 2008, 15:37 -
Converting an ASF (WMV) file
By yadda in forum Newbie / General discussionsReplies: 1Last Post: 7th Nov 2007, 06:16
