hello. I made a DVD of a videotape i have. When playing it in a portable Philips DVD player, it looks good and all that. The only problem is, i can't fast forward to parts of the video without the sync between the video and audio messing up.
Can someone suggest something so i can fix the original DVD files?
thanks!
hi! The source video format was originally a video tape. I converted it to DVD with a Pioneer DVD Recorder, and then put that DVD into my pc to edit parts out. I should have used a DVD-RW and used my DVD Recorder's editing features, but i didn't have one handy. Anyway, i then used AVIDemux and converted it to an MPEG2 file. I am not really that experienced with AVIDemux, like choosing the best file format to save it with. I then re-authored it with DVD Movie Factory 3. So far, i tried fast forwarding in the Philips portable DVD player, with sync issues. I will check other things with it and post another reply.
thanks!
Fast forwarding and rewinding a tape before capture?
By justin81 in forum RestorationReplies: 4Last Post: 14th May 2010, 16:41 -
Video freezing when fast-forwarding.
By xcodyj in forum Newbie / General discussionsReplies: 1Last Post: 4th May 2010, 03:45 -
Viewing during VCR fast forwarding/rewinding
By spinmonk in forum Capturing and VCRReplies: 12Last Post: 30th Aug 2009, 18:30 -
ogm's fast forwarding
By CommanderZero in forum Newbie / General discussionsReplies: 2Last Post: 21st Oct 2007, 23:23 -
fast forwarding flvs with vlc?
By majax79 in forum Software PlayingReplies: 2Last Post: 20th Sep 2007, 13:54
