This is strange: I captured some video clips from a Tape, and it occured that the videos shorter than 6 minutes worked alright, but the clips longer than 6 minutes length had audio for the first 2 minutes only, the audio stopped at 2.03 into the track. I used VirtualDub for capture and a TerraTec TValue card. While capturing everything sounded fine, after capturing I cut the starts and ends of the files, everything as usual.
Since this mistake occured regularly, I hope there is a reason and a solution! How about that?
added: I captured into uncompressed avi
so doesnt anyone have an idea for this? -
How long is the reulting (uncompressed file) ? What kind of file systems do you use (fat32 or NTFS) ? If FAT32, you know about the 4GB filesize limit?
I use fat32. I know the 4GB problem, but the uncompressed avi I recorded off tape were all below 4GB. But hey, all files in which that sound error occured, were bigger than 2GB!!! What about that?
The 2 GB limit is the avi type-2 limit (I believe).Thiy means, that files produced by virtualdub cannot be read by all programs (some can).I encounter this prob with files > 9 Min (DV compressed).I don't know, if this is related to your problem!
I had a similar problem once when I used TMPGenC to cut part of an AVI file out into another AVI file. If I remember correctly, this quote from another posting was the solution:
"In case this was a simular issue to what I was seeing, the answer (pointed out to me by KuskenLars) to go into TMpgEnc->Enviorment Settings->VFAPI Plug-In, click on "Direct Show Multimedia File Reader", and right click to up it's priority until it was on top."
Check and see if VirtualDub has a similar setting.
Virtualdub avi capture audio sync issues
By buckethead in forum Capturing and VCRReplies: 8Last Post: 31st Oct 2011, 15:34 -
TV Capture with EasyCAP and VirtualDub Audio out of sync
By olobay in forum Capturing and VCRReplies: 9Last Post: 29th May 2011, 19:19 -
4.6G 120 minute disk giving only 113 minutes at 27% quality Why?
By Emerogork in forum MediaReplies: 22Last Post: 12th Aug 2009, 12:05 -
FitCD thinks 43 minute video is 2 minutes long - ditto TMPGEnc
By natrap in forum Video ConversionReplies: 3Last Post: 2nd Aug 2009, 22:02 -
Only recorded 30 minutes on a 60 minute tape, can't capture
By kyroha in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 11th Jun 2007, 10:40
