The part of the log in bold is where it stops. Does this mean the HDD writes are faulty? I do have reason to believe that disk is dying... should this issue go away by using another drive as temp? (100s of free gigs on the drive in question)
Code:d:\>"E:\=DOWNLOADS\PROGRAMS\MEDIA\RIP\RIPBOT\tools\bepipe\bepipe.exe" --script "import(^d:\Temp\RipBot264temp\job4\job4.avs^)" | d:\>"E:\=DOWNLOADS\PROGRAMS\MEDIA\RIP\RIPBOT\tools\avs2yuv\pipebuf.exe" "E:\=DOWNLOADS\PROGRAMS\MEDIA\RIP\RIPBOT\tools\avs2yuv\avs2yuv.exe" "d:\Temp\RipBot264temp\job4\job4.avs" -raw - : "E:\=DOWNLOADS\PROGRAMS\MEDIA\RIP\RIPBOT\tools\x264\x264_x64.exe" --pass 1 --bitrate 10000 --stats "d:\Temp\RipBot264temp\job4\job4.stats" --fps 24000/1001 --min-keyint 24 --keyint 240 --frames 216266 --sar 1:1 --level 4.1 --vbv-bufsize 50000 --vbv-maxrate 25000 --filter -3,-3 --ref 8 --bframes 3 --b-adapt 1 --subme 9 --aq-mode 1 --trellis 1 --partitions all --me umh --output "d:\Temp\RipBot264temp\video.264" - 1920x820 : 2 x264 [info]: 1920x820 @ 23.98 fps x264 [info]: using SAR=1/1 x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.1 Cache64 x264 [info]: profile Main, level 4.1 d:\Temp\RipBot264temp\job4\job4.avs: 1920x820, 10000000/417083 fps, 216266 frames x264 [info]: frame I:2871 Avg QP:18.92 size:139331 x264 [info]: frame P:154560 Avg QP:21.81 size: 57678 x264 [info]: frame B:58835 Avg QP:23.55 size: 25207 x264 [info]: consecutive B-frames: 49.6% 39.2% 5.3% 5.9% x264 [info]: mb I I16..4: 33.5% 0.0% 66.5% x264 [info]: mb P I16..4: 49.5% 0.0% 0.0% P16..4: 44.2% 0.0% 0.0% 0.0% 0.0% skip: 6.3% x264 [info]: mb B I16..4: 11.7% 0.0% 0.0% B16..8: 26.6% 0.0% 0.0% direct:26.3% skip:35.5% L0:22.7% L1:33.4% BI:43.9% x264 [info]: final ratefactor: 19.48 x264 [info]: coded y,uvDC,uvAC intra: 88.0% 51.3% 12.4% inter: 44.1% 23.5% 0.6% x264 [info]: i16 v,h,dc,p: 19% 10% 49% 21% x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 20% 11% 17% 9% 10% 9% 7% 9% 7% x264 [info]: Weighted P-Frames: Y:5.5% x264 [info]: kb/s:9576.63 encoded 216266 frames, 28.79 fps, 9576.63 kb/s :\>"E:\=DOWNLOADS\PROGRAMS\MEDIA\RIP\RIPBOT\tools\avs2yuv\pipebuf.exe" "E:\=DOWNLOADS\PROGRAMS\MEDIA\RIP\RIPBOT\tools\avs2yuv\avs2yuv.exe" "d:\Temp\RipBot264temp\job4\job4.avs" -raw - : "E:\=DOWNLOADS\PROGRAMS\MEDIA\RIP\RIPBOT\tools\x264\x264_x64.exe" --pass 2 --bitrate 10000 --stats "d:\Temp\RipBot264temp\job4\job4.stats" --fps 24000/1001 --min-keyint 24 --keyint 240 --frames 216266 --sar 1:1 --level 4.1 --vbv-bufsize 50000 --vbv-maxrate 25000 --filter -3,-3 --ref 8 --bframes 3 --b-adapt 1 --subme 9 --aq-mode 1 --trellis 1 --partitions all --me umh --output "d:\Temp\RipBot264temp\video.264" - 1920x820 : 2 x264 [info]: 1920x820 @ 23.98 fps x264 [info]: using SAR=1/1 x264 [warning]: DPB size (8 frames, 19169280 bytes) > level limit (5 frames, 12582912 bytes) x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.1 Cache64 x264 [info]: profile High, level 4.1 d:\Temp\RipBot264temp\job4\job4.avs: 1920x820, 10000000/417083 fps, 216266 frames Output error: wrote only 2360704 of 2361600 bytes x264 [info]: frame I:1026 Avg QP:19.94 size:136894 x264 [info]: frame P:54033 Avg QP:22.38 size: 62754 x264 [info]: frame B:19431 Avg QP:23.89 size: 30773 x264 [info]: consecutive B-frames: 49.3% 44.6% 5.3% 0.8% x264 [info]: mb I I16..4: 1.7% 91.5% 6.8% x264 [info]: mb P I16..4: 0.4% 11.4% 0.8% P16..4: 48.0% 22.8% 13.2% 0.1% 0.1% skip: 3.2% x264 [info]: mb B I16..4: 0.0% 1.7% 0.2% B16..8: 53.8% 1.8% 2.8% direct:10.0% skip:29.6% L0:41.3% L1:42.0% BI:16.7% x264 [info]: 8x8 transform intra:90.5% inter:66.8% x264 [info]: coded y,uvDC,uvAC intra: 92.7% 73.0% 22.7% inter: 56.3% 42.8% 1.0% x264 [info]: i16 v,h,dc,p: 38% 10% 10% 42% x264 [info]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 10% 4% 3% 12% 17% 17% 13% 14% 11% x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 24% 3% 2% 9% 14% 16% 11% 11% 9% x264 [info]: Weighted P-Frames: Y:4.4% x264 [info]: ref P L0: 42.9% 15.1% 17.7% 6.4% 5.4% 4.2% 3.7% 2.3% 2.2% 0.1% x264 [info]: ref B L0: 69.8% 10.7% 6.9% 4.1% 3.3% 2.8% 2.5% x264 [info]: kb/s:10632.41 encoded 74490 frames, 3.17 fps, 10632.41 kb/s d:\>"E:\=DOWNLOADS\PROGRAMS\MEDIA\RIP\RIPBOT\tools\mkvtoolnix\mkvmerge.exe" -o "G:\wolf VERTIGGO LITE 2pass.mkv" --title "wolf VERTIGGO LITE 2pass" --default-duration 0:24000/1001fps -d 0 -A -S "d:\Temp\RipBot264temp\video.264" mkvmerge v3.0.0 ('Hang up your Hang-Ups') built on Dec 12 2009 15:20:35 'd:\Temp\RipBot264temp\video.264': Using the AVC/h.264 ES demultiplexer. 'd:\Temp\RipBot264temp\video.264' track 0: Extracted the aspect ratio information from the MPEG-4 layer 10 (AVC) video data and set the display dimensions to 1920/820. 'd:\Temp\RipBot264temp\video.264' track 0: Using the MPEG-4 part 10 ES video output module. The file 'G:\wolf VERTIGGO LITE 2pass.mkv' has been opened for writing. The cue entries (the index) are being written... Muxing took 192 seconds. ------------------------- Elapsed Time: 08h:41m:04s
Here's a log of a sucessful encode to MKV, starting at the same place:
D:\>"D:\DOWNLOADS\RipBot264v1.14.5\tools\x264\x264 _x86.exe" "D:\temp\RipBot264temp\job1\job1.avs" --pass 1 --bitrate 9276 --stats "D:\temp\RipBot264temp\job1\job1.stats" --fps 24000/1001 --min-keyint 24 --keyint 240 --sar 1:1 --level 4.0 --aud --nal-hrd --vbv-bufsize 25000 --vbv-maxrate 25000 --filter 0,0 --ref 3 --bframes 3 --b-adapt 1 --direct auto --subme 7 --aq-mode 1 --trellis 1 --partitions all --me umh --output "D:\temp\RipBot264temp\video.264"
avis [info]: 1920x1080 @ 23.98 fps (160344 frames)
x264 [warning]: VBV bitrate (25000) > level limit (20000)
x264 [info]: profile Main, level 4.0
x264 [info]: frame I:2670 Avg QP:17.45 size:174607
x264 [info]: frame P:86909 Avg QP:21.97 size: 54939
x264 [info]: frame B:70765 Avg QP:22.20 size: 32568
x264 [info]: consecutive B-frames: 24.8% 43.1% 9.2% 23.0%
x264 [info]: mb I I16..4: 60.2% 0.0% 39.8%
x264 [info]: mb P I16..4: 32.6% 0.0% 0.0% P16..4: 36.3% 0.0% 0.0% 0.0% 0.0% skip:31.1%
x264 [info]: mb B I16..4: 5.7% 0.0% 0.0% B16..8: 25.7% 0.0% 0.0% direct:25.5% skip:43.2% L0:31.4% L1:45.7% BI:22.9%
x264 [info]: final ratefactor: 19.41
x264 [info]: direct mvs spatial:98.5% temporal:1.5%
x264 [info]: coded y,uvDC,uvAC intra: 67.3% 79.6% 62.1% inter: 22.3% 29.8% 7.5%
x264 [info]: i16 v,h,dc,p: 27% 16% 35% 23%
x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 16% 16% 20% 8% 9% 8% 8% 7% 8%
x264 [info]: kb/s:9026.24
encoded 160344 frames, 28.14 fps, 9026.24 kb/s
D:\>"D:\DOWNLOADS\RipBot264v1.14.5\tools\x264\x264 _x86.exe" "D:\temp\RipBot264temp\job1\job1.avs" --pass 2 --bitrate 9276 --stats "D:\temp\RipBot264temp\job1\job1.stats" --fps 24000/1001 --min-keyint 24 --keyint 240 --sar 1:1 --level 4.0 --aud --nal-hrd --vbv-bufsize 25000 --vbv-maxrate 25000 --filter 0,0 --ref 3 --bframes 3 --b-adapt 1 --direct auto --subme 7 --aq-mode 1 --trellis 1 --partitions all --me umh --output "D:\temp\RipBot264temp\video.264"
x264 [info]: profile High, level 4.0
x264 [info]: frame I:2670 Avg QP:17.79 size:196362
x264 [info]: frame P:86909 Avg QP:22.71 size: 59839
x264 [info]: frame B:70765 Avg QP:23.77 size: 28257
x264 [info]: mb I I16..4: 22.2% 69.6% 8.3%
x264 [info]: mb P I16..4: 1.6% 10.6% 0.7% P16..4: 36.7% 10.9% 9.4% 0.1% 0.1% skip:29.8%
x264 [info]: mb B I16..4: 0.2% 1.3% 0.1% B16..8: 42.3% 0.9% 1.7% direct: 5.0% skip:48.6% L0:45.0% L1:50.3% BI: 4.7%
x264 [info]: 8x8 transform intra:80.4% inter:76.5%
x264 [info]: direct mvs spatial:90.2% temporal:9.8%
x264 [info]: coded y,uvDC,uvAC intra: 75.5% 85.9% 71.7% inter: 27.5% 39.5% 14.0%
x264 [info]: i16 v,h,dc,p: 56% 21% 5% 18%
x264 [info]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 12% 11% 34% 7% 7% 7% 7% 7% 7%
x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 18% 23% 16% 6% 9% 8% 8% 6% 6%
x264 [info]: ref P L0: 76.0% 15.1% 8.9%
x264 [info]: ref B L0: 87.5% 12.5%
x264 [info]: kb/s:9240.23
encoded 160344 frames, 10.01 fps, 9240.23 kb/s
D:\>"D:\DOWNLOADS\RipBot264v1.14.5\tools\mkvtoolnix\mkvmerge.exe" -o "E:\MKV\PUSH.mkv" --title "PUSH" --default-duration 0:24000/1001fps -d 0 -A -S "D:\temp\RipBot264temp\video.264" --language 0:und -a 0 -D -S "D:\temp\RipBot264temp\audio.ac3" --chapters "D:\temp\RipBot264temp\job1\chapters.txt"
mkvmerge v2.9.8 ('C'est le bon') built on Aug 13 2009 12:49:06
'D:\temp\RipBot264temp\video.264': Using the AVC/h.264 ES demultiplexer.
'D:\temp\RipBot264temp\audio.ac3': Using the AC3 demultiplexer.
'D:\temp\RipBot264temp\video.264' track 0: Extracted the aspect ratio information from the MPEG-4 layer 10 (AVC) video data and set the display dimensions to 1920/1080.
'D:\temp\RipBot264temp\video.264' track 0: Using the MPEG-4 part 10 ES video output module.
'D:\temp\RipBot264temp\audio.ac3' track 0: Using the AC3 output module.
The file 'E:\MKV\PUSH.mkv' has been opened for writing.
Muxing took 144 seconds.
Elapsed Time: 06h:06m:27s -
Uh... What is this going to explain? I know what a successful one looks like, I've done dozens. However, just recently it's been dying on me, and in wildly different places (half way, 5min from done, etc.)
BD Rebuilder: ERROR "failed video encode, aborted"
By jlm86 in forum Blu-ray RippingReplies: 1Last Post: 22nd Feb 2011, 18:57 -
What is the problem when it says "failed video encode, aborted "?
By PERSHON in forum Newbie / General discussionsReplies: 8Last Post: 17th Feb 2011, 12:33 -
[Sony Vegas Pro 10] GPU "acceleration" = slower encode?
By DragonQ in forum Video ConversionReplies: 3Last Post: 11th Jan 2011, 15:32 -
Ripbot takes forever to "Please Wait... Initializing..."
By nikemouse in forum Blu-ray RippingReplies: 13Last Post: 21st Mar 2010, 15:12 -
"Encode video to audio duration" causes menu background jitter/no
By Fairy in forum SVCD2DVD & VOB2MPGReplies: 9Last Post: 8th Feb 2008, 16:02
