Results 1 to 10 of 10
    Dec 2005
    I just opened a new pack of Verbatim DVD+R 16X
    Imageburn showed them as: Disc ID: RITEK-F16-01
    Is this the normal ID for these discs, just wondering.
    I also purchased some Verbatim DVD+R DL 2.4X
    Disc ID: MLK-001-00
  2. Renegade gll99's Avatar
    May 2002
    Canadian Tundra
    My DVD+R 16x 100 cakebox Verbatim are MCC 004
    There's not much to do but then I can't do much anyway.
    Mar 2003
    If they're Value Line, then they're legit, but you should avoid them.
    If they're DataLifePlus, then they're fake.
    Dec 2005
    I purchased these
    Verbatim Silver Thermal Lacquer 16X DVD+R Branded Media 4.7GB 50 Pack in Cake Box
    This is the first time with the Ritek ID they have always been MCC 004
    Mar 2003
    Where'd you buy them? They're the plain discs in the plain packaging w/ the Verbatim sticker on the cake box, right?
    Dec 2005
    Thank you for your time, they where packaged like these
    http://www.supermediastore.com/product/u/verbatim-95037-silver-thermal-lacquer-16x-dvd...y%3D50+Pack%7C
    They were not purchased from surermedia store
  7. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    ^^^Where ever you purchased them from it must be fakes or Verbatim is stooping low and their outsourcing to Ritek.
    Value Series = Ritek or CMC
    Where were these bought from?
    Mar 2003
    The pictured packaging doesn't say Value Series (It doesn't say Datalife Plus either).
  10. Renegade gll99's Avatar
    May 2002
    Canadian Tundra
    That image looks like the wrapper is all dark blue but if it has the usual lighter mauve/purple band in the middle then it's like the 50 pack cakebox I bought just after I picked up the 100 pack. I checked a disk and they are also MCC 004. I picked these up about 3 months ago at Staples Canada. I hope they haven't changed them the MCC have been very reliable.
    btw) The disk writing looks the same as the pic except the center is clear. It looks solid white in the pic but that could just be the background showing through.
