Hello,
I'm trying to use ffmpegX to convert various video clips for viewing on a PSP. The program appears to run perfectly, importing and converting all formats I've tried (MPEG2, MPEG1, MPEG4, MOV etc., etc., etc.!)... however the conversion process takes only about a second to complete, and the resulting files are all zero KB. I cant open any of them in quicktime, and when I transfer them to the PSP they show up in the movies list but don't play, giving me a corrupted file message instead.
I've tried using another program on my old PC but that doesn't work it either. How hard can it be??!!
Can anyone help?
Thanks a mill'
Thought I had it figured out after searching another thread, which points to a problem with audio. The files I'm trying to convert don't have audio, so after unchecking the "encode audio" button under the audio tab, it converted a file that Quicktime can open, but the PSP now says it's unreadable, so my problem continues under a different guise.
Aslo, theres no Thumbnail image for the file on my PSP, just a generic graphic.
Thanks for any insights..Last edited by Peter Sarkisian; 14th Feb 2010 at 15:48. Reason: Thought problem was fixed but its not
I cant seem to convert anything that works. The PSP (XviD) setting wont play on the PSP, and the PSP H264 just gives me a failed message when converting. Here are several post-conversion info messages:
- "Info" message following unplayable PSP XviD MP4 conversion (note, this file plays fine using quicktime, but wont play on the PSP:
"... 1 video MPEG-4 Unknown Profile(0), 15.081 secs, 0 kbps, 320x240 @ 29.97 fps"
- "Info" message following PSP H264 Failed conversion:
"Could not write header for output file #0 (incorrect codec parameters ?)"
Perhaps the PSP wants movie clips to have a video track and an audio track to see them as valid movie files?
The PSP H.264 preset in ffmpegX surely wants an audio track; it says so in the log:Maybe you could add a silent audio track [1] to your source file, maybe then ffmpegX converts fine and the output will be readable by the PSP?[psp @ 0x4701fc]PSP mode need one video and one audio stream
[1] You could use Audacity to generate silence for the same length as the video, save it as WAV, and add that to your video.
ffmpegx conversion produces empty files
By aherodias in forum ffmpegX general discussionReplies: 1Last Post: 26th Jun 2011, 04:14 -
ffmpegx occasionally creates 0kb files instead of encoding properly
By digitalgeist in forum ffmpegX general discussionReplies: 12Last Post: 27th Dec 2009, 19:22 -
PSP v3.30 Video Specs for ffmpegX
By persona1138 in forum ffmpegX general discussionReplies: 25Last Post: 27th Apr 2009, 11:45 -
Anyone have ffmpegX 0.0.9x r1???? 0.0.9y creating PSP corrupted files
By kram_audio in forum ffmpegX general discussionReplies: 15Last Post: 27th Jun 2008, 23:16 -
ffmpegX and PSP h.264
By str in forum ffmpegX general discussionReplies: 4Last Post: 25th Feb 2008, 08:08
