Hi....It's really strange, I tried to convert a mov file to flash, maintaining the source window size, 384x288, 4/3 PAL. Encoding seemed ok, but when I open flv, it's smaller, I suppose in the ffmpeg preset 4/3 window, 320x.....
I tried it several times...nothing changed.
Anbybode knows what's problem?
Thank you
Amedeo
Did you:
- Open your source file;
- Then set a preset (FLV);
- Then alter the target video size to match the source (384x288);
- Then start the encode?
If I do a MOV to FLV conversion that way, the output frame size is exactly as I intended. That is, I can't seem to replicate your issue.
Also, how did you measure the output resolution? Which player?
Problem with MOV > FLV conversion
By sprinke in forum ffmpegX general discussionReplies: 1Last Post: 12th Feb 2011, 21:11 -
Mencoder cannot encode MP4/MOV/FLV with global headers!?
By dom_b in forum Video ConversionReplies: 0Last Post: 2nd Jul 2010, 06:07 -
Mpeg file size balloons after exporting as FLV or MOV?
By jjachin in forum Newbie / General discussionsReplies: 2Last Post: 16th Jul 2009, 16:56 -
Problem trying to convert .flv to .mov
By herdofcaribou in forum ffmpegX general discussionReplies: 7Last Post: 10th Feb 2008, 01:16 -
Problems trying to encode .mov to .flv
By bneubert in forum ffmpegX general discussionReplies: 2Last Post: 19th Jul 2007, 15:17
