Hi All!
I am looking for the name of an application which will take a directory full of photos and output a slideshow as a movie with differing transitions. Also, the transitions has to be in synch with the music.
Quite a while back, I watched a video being created with music and the guy was simply tapping at the keyboard in time with the music...and different transitions happened. Very nice it was.
Can anybody help?
Results 1 to 25 of 25
Unfortunately, no...that's not it.
Quote: "What would be really cool (and I don't even know if this is possible or not) is the ability to manually "tap through" the slides in tempo with the background music, in real-time - or some other way of syncing up the slideshow to the beat of the music?"
Which is exactly what I seen...I am just looking for the app name.
ProShow can: but you have to set the timing of each slide to make this happen. If you're into doing the work, and willing to pay for it (a free trial is available): I recommend the software.
;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
Nope, that's not the one going by your description. The one I want makes the timing of the slides easy peasy...no guess work - just the tapping of an arrangement of keys for the transitions!
Yeah, good luck with that.
is not going to bewith differing transitions. Also, the transitions has to be in synch with the music.
easy peasy...no guess work - just the tapping of an arrangement of keys for the transitionsWant my help? Ask here! (not via PM!)
You're probably talking about Premiere. There was a video tutorial a few years back on wrigley video tutorials that shows just that. I believe he was using vesion 6 or 6.5 if I'm not mistaken. He would import the folder of images into the time line, add the music, then when he played the music he would hit a key to insert key points for image transitions.
Do a search, they probably still have it up there. It might be called creating a slideshow montage or something like that.........Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
Hmm I'm in need of such a software also. I think Slideshow Movie Maker has such a feature (you can tap along to the beat of the music and create the keypoints for transitions). I don't know anything that works in realtime, sounds like V-jay software to me? Please post here if you find anything!
"Just another sheep boy, duck call, swan
song, idiot son of donkey kong - Julian Cope" -
You know that you are looking for the name of an app. I don't know what it is called...
However if the question is how to sync a slideshow to the beat of music here's a way to calculate it.
First you must find the beat per. minute value of your music. This soft can do this for free: http://www.vicman.net/getfree/BPM-Analyzer_27727s.html
Then you'll have to find the beat per. frame(PAL=25 fps/Ntsc=29.97 fps): This nifty online tool can do that for you: http://zambari.info/av_calc.php
Remember to set the PAL/NTSC correctly. BTW. you can actually tap to your music with this tool too and get the BPM.
Now you have BPF(rame) you can just set the values in your DVD slideshow authoring app accordingly. (After deciding on where you want the transition - beginning of the beat, in the middel of the beat or after?) -
No, quite easy...
Open this site: http://zambari.info/av_calc.php
Select Pal or Ntsc
Play your music in your music player and click on the tap button in the rythm.
EX BMP: 150= 10 frames pr. beat.
In DVD slideshow GUI:
Select Pal or Ntsc
Import your images.
Select all images and hit Slide Settings.
Set the slide duration to 40(transition every 4. beat).
Set the transiton to 'Cut'(means no transition aka. transition duration is overruled).
And render your slideshow or burn it directly to a dvd.Last edited by tin2tin; 15th Feb 2010 at 07:34.
maybe fotomagico?
http://www.ehow.com/video_4992782_fotomagico-tutorial-audio-markers.html
I know you can do something similar in after effects with layer markers , but you have to specify which transition afterwards by advancing to markers (i.e it's not done in real time, only the layer markers are placed in real time) -
I found the video tutorial. He used Premiere 6 to do it.
http://www.wrigleyvideo.com/videotutorial/tutdes_montagetomusic.htmGot my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
I just downloaded and watched the .wmv tutorial from the link above. RacerX mentioned this very same think (Premier and Wrigley Video) two days ago.
Premiere isn't "easy peasy" either.
WinVDR like application for Linux?
By BlooderButcher in forum LinuxReplies: 2Last Post: 13th Nov 2009, 08:28 -
Application Error
By Jmorales27 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 10th Jul 2008, 14:35 -
Where is the coupon application?
By moviebuff2 in forum Newbie / General discussionsReplies: 5Last Post: 2nd Jan 2008, 13:15 -
COLOR application
By Tom in HD in forum MacReplies: 2Last Post: 2nd Dec 2007, 00:09 -
reg the application to use
By liddu in forum Newbie / General discussionsReplies: 4Last Post: 22nd Aug 2007, 03:31
