Hi guys! I have some anime files that are mp4 or avi but for some reason they show as unsupported files. I tried using ps3 media player and that didn't work, also I don't want to stream movies from my pc. I simply want to copy then to my ps3 hdd so I can play them without the need of having my pc on. Anyway my questions is how can I fix these files and how do I go about it?
Any help will be greatly appreciated.
Thanks for the info. The problem is that I'm a complete noob when it comes to this... and I really have no idea what is wrong. I tried to remux to .m2ts and I got the file to play but it gives me no sound. Here is what I got from a file that won't work from mediainfo"
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 223 MiB
Duration : 23mn 5s
Overall bit rate : 1 352 Kbps
Encoded date : UTC 2007-03-21 02:29:10
Tagged date : UTC 2007-03-21 02:29:10
Video
Format : AVC
Format profile : High@L5.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : avc1
Duration : 23mn 5s
Bit rate mode : Variable
Bit rate : 1 220 Kbps
Maximum bit rate : 5 055 Kbps
Width : 704 pixels
Height : 400 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.181
Stream size : 201 MiB (90%)
Writing library : x264 core 54 svn-634
Encoding settings : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x3:0x133 / me=hex / subme=5 / brdo=0 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=1 / nr=0 / decimate=1 / mbaff=0 / bframes=2 / b_pyramid=1 / b_adapt=1 / b_bias=1 / direct=2 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc=2pass / bitrate=1220 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30
Encoded date : UTC 2007-03-20 23:09:00
Tagged date : UTC 2007-03-21 02:29:49
Audio
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : 40
Duration : 23mn 5s
Bit rate : 128 Kbps
Maximum bit rate : 179 Kbps
Channel(s) : 2 channels
Channel positions : L R
Sampling rate : 48.0 KHz
Stream size : 21.1 MiB (9%)
Language : English
Encoded date : UTC 2007-03-21 02:29:45
This is a file that does work or play on my PS3:
Format : MPEG-4
Codec ID : isom
File size : 228 MiB
Duration : 23mn 5s
Overall bit rate : 1 381 Kbps
Encoded date : UTC 2008-07-10 08:51:56
Tagged date : UTC 2008-07-10 08:51:56
Video
Format : AVC
Format settings, ReFrames : 1 frame
Codec ID : avc1
Duration : 23mn 5s
Bit rate : 1 250 Kbps
Maximum bit rate : 5 786 Kbps
Width : 704 pixels
Height : 400 pixels
Resolution : 8 bits
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.185
Stream size : 207 MiB (91%)
Writing library : x264 core 60 r906 ceb2df9
Encoding settings : cabac=1 / ref=1 / deblock=0:0:0 / analyse=0x3:0x133 / me=dia / subme=4 / brdo=0 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=1 / nr=100 / decimate=0 / mbaff=0 / bframes=0 / keyint=250 / keyint_min=25 / scenecut=40 / rc=2pass / bitrate=1250 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=0
Encoded date : UTC 2008-07-10 07:25:59
Tagged date : UTC 2008-07-10 08:52:48
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 23mn 5s
Bit rate : 128 Kbps
Maximum bit rate : 236 Kbps
Encoded date : UTC 2008-07-10 08:52:41
Any help will be greatly appreciated. -
PS3 Media Server won't play MPG or TS files.
By lovelylisa in forum Software PlayingReplies: 9Last Post: 27th Feb 2012, 11:59 -
Blu-Ray to Mp4 x.264 1080p won't play on PS3
By Patrick_H in forum Media Center PC / MediaCentersReplies: 3Last Post: 31st Dec 2010, 11:53 -
How can I play mp4 files with subtitles on PS3?
By furtem in forum SubtitleReplies: 8Last Post: 24th Jan 2010, 15:03 -
How to edit mp4 files and play them on my PS3?
By FlipUser in forum Video ConversionReplies: 3Last Post: 21st Oct 2009, 18:25 -
PS3 won't play AVI's after splicing.
By zsaz1029 in forum Video ConversionReplies: 2Last Post: 23rd Feb 2008, 08:59
