Ok, i have a problem i want to split a video file into segment of 3 second exacly (not an average, or sometime 2 sec, sometime 4 sec, sometime 10 sec.) I've tried a lot of splitter and everyone split into variable part or part of 10 sec (virtualdub).
How can i make exact part of 3 sec.
The split work with Xilisoft.
The split didnt work with : Easy video spliter, virtualdub, avisplit classic -
You could do it with Virtualdub, if you knew how to use it. Same with AVI Demux. Enable smart-rendering in Virtualdub instead of just trying to direct stream copy the chunks and you can cut where you like. If you just use direct stream copy you can only cut on i-frames, which can be 300 frames apart (around 10 seconds). Xilisoft probably worked because it re-encodes everything anyway
Read my blog here.
Virtualdub is the easiest way.
*** Now that you have read me, do some other things. ***
Video split
By Videographer in forum EditingReplies: 1Last Post: 6th Feb 2012, 10:31 -
VobBlanker DVD Split- Automatically jump to Split Title
By src2206 in forum DVD RippingReplies: 12Last Post: 11th Dec 2008, 07:58 -
How to split video to different size each
By sirganisch in forum Newbie / General discussionsReplies: 3Last Post: 6th Jun 2008, 13:40 -
Procoder split/split by size/media query
By kippard in forum Authoring (DVD)Replies: 7Last Post: 17th Nov 2007, 22:35 -
Split Video
By Russo in forum EditingReplies: 6Last Post: 2nd Nov 2007, 10:52
