Hi guys,
I'm new to the Pro/prosumer Camcorder market and I need help selecting a new video camera.
I'm looking at getting the Canon XHA1s (because of the features it offers, footage quality and the good name it has) but the more I search the internet the more I read about how Mini DV is going "out of fashion" in the technology world.
I'm yet to find a Video camera with the quality of the XHA1s but a Flash memory version. I know Sony just brought out the HDR-AX2000 but it records to 'memory stick duo'. Does anyone know a flash based video camera that has about the same manual control features and inputs+outputs as the Canon XHA1s or am I better to stick with the XHA1s?
I really don't know what to do.
Basically I'm going to use it for a range of projects from documentary's to short film making,
I need it to have XLR inputs (so I can run a RODE NTG-1 mic)
and I most defiantly want 3x CCD or CMOS chips
any help would be great!
Thanks,
Zano.
Look at Sony Z5 or Z7. Both can record to compact flash cards and have all of the pro features you are looking for. I have both, they are great cameras!
i don't think the sony's are even in the ballpark of the xha1. a single 1/3 inch cmos sensor vs. 3 - 1/3 inch ccds? i use cmos HDV cams but the ccds have so many fewer issues. the worst being i hate having to plan everything around the cmos rolling shutter
the interchangeable lens system on the z7 would be a nice feature to have i'll give it that.--
You didn't mention your budget, but you can't go wrong with The PMW-EX1R utilizes three 1/2-inch type Exmor CMOS sensors, each with an effective pixel count of 1920 (H) x 1080 (V):
http://pro.sony.com/bbsc/ssr/cat-broadcastcameras/cat-xdcam/product-PMWEX1R/ -
I would argue that HDV still has plenty of life left in it, at least enough to warrant 1 more camera cycle.
Look at the still very solid Sony Z1 as a possible option, for what you expect of it I still think it as a fantastic camera. If you have a smaller budget then the HVR-V1 is a great camera for the money as well, but there are more options at that budget level. We still use both where I work and are happy to continue with HDV as a stable workflow. We have more issues with the flash disk workflow at the moment than the HDV flow. Not to say that the move isnt a good thing, it is, just wanted to clear up that HDV isn't as past as you might think. -
The Z5 and Z7 are 3 cmos, never had the rolling shutter issue and images are stunning. I would put them in ball park above the Canon. Very solid units. -
the reviews on the z7 rolling shutter cmos problem are mixed, some claim it's there and some not. strange as it's a chip type problem, in that cmos chips are "read" sequentially from top pixels to bottom, not all at once.
if you shoot set shots from a tripod you would never see it, as it is only evident as skew in moving objects.--
Newb Needs Advice - New PC, New Camcorder
By LifeShots in forum Newbie / General discussionsReplies: 5Last Post: 15th Feb 2010, 12:15 -
Advice on getting HD Camcorder
By davidallengould in forum Newbie / General discussionsReplies: 1Last Post: 30th Dec 2009, 11:15 -
Camcorder Advice
By animalized in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 29th Jul 2009, 15:42 -
New Camcorder Suggestions Needed
By wangy26 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 6th May 2009, 15:28 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 18:30
