I'm finding the excellent resolution seen on the preview screen of Showbiz dvd2(VC100U Hardware) as the vhs is captured, seems to become inferior after burning & playing on TV. The vhs tapes vary in length between 1 - 2.5hrs if longer I edit into 2discs to avoid compression & maintain resolution, depending on the length I adjust the Bitrate between 3 & 5, if only an hour long, can get away will 7. TV screens in my area have a height that is 75% of the width, so I use the frame size 720x576, is this correct or might 320x240 create better resolution on the TV.
I'm thinking to upgrade to dual core, 2.6GHz - is a Graphics Card with Video Capturing Capabilities a good thing to add in addition to the VC100U, or instead of? Thanx
Results 1 to 1 of 1
Please help! Problem with using TBC to capture VHS tapes.
By jrodefeld in forum Capturing and VCRReplies: 9Last Post: 9th Jun 2011, 18:08 -
Why is Powewrdirector8 audio out sync when Showbiz DVD2 isn't
By chris18 in forum Capturing and VCRReplies: 4Last Post: 20th Feb 2010, 11:57 -
Very strange VHS to PC capture problem
By fredhoward in forum Capturing and VCRReplies: 45Last Post: 9th Feb 2010, 09:30 -
VHS Capture Problem
By sdculp in forum Newbie / General discussionsReplies: 7Last Post: 15th Nov 2008, 09:58 -
ArcSoft ShowBiz Audio Problem
By KenOBrien in forum Newbie / General discussionsReplies: 0Last Post: 5th May 2007, 07:29
