Have a 22x samsung ext writemaster , when making back ups of my shows , buring one after another, the 6th or 7th burn always fails , EVERYTIME ! Can burn upto 5 or 6 in a row everytime, then it fails have to close NERO and turn drive off for 10 sec then back on again , everything ok till the 6 th dvdr again. ANY IDEAS ??
first thing i would try is another type of media...i.e...media code...if thats not it then i would burn the first 6...then wait a few minutes...maybe 5 or 10 and try it...i had this happen with my lite on and it was 2 things...media was crap and also there were processes running in the background that created a lockdown on imgburn and the disc would just stay at like 10% and do nuthin until i reset my pc...i started to wait a while so all apps in the background quit running and i havent had an issue since....oh yeah...also use imgburn over nero
If you are burning one after the other, your burner may be overheating. If you wait ten minutes or so, does the sixth or seventh burn? And I would also recommend ImgBurn over Nero for burning just about anything.
But with either program, post a copy of the burning log and there should be an error shown that might explain the problem.
There is also a chance that the buffer for the drive isn't refreshing and it runs out of space.
Also, when you said you 'turn drive off for 10 sec then back on again', is that an external burner? If so, on a USB connection?
And this isn't authoring. Moving you to our DVD & Blu-ray Writers forum.
Samsung BD-C6500T fails Gateway Ping Test. Why?
By North43West80 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 20th Mar 2011, 13:36 -
DVD Styler Fails to Burn
By mik1 in forum Authoring (DVD)Replies: 1Last Post: 10th Jun 2010, 02:57 -
DL+ burn fails with ISO file larger than 7 Gig. Why?
By anubis13 in forum DVD RippingReplies: 5Last Post: 5th Dec 2009, 19:48 -
UGH!!!! READ problems again, this time with Sony DVD burner Sata 22x
By Clint Eastwood in forum DVD & Blu-ray WritersReplies: 5Last Post: 15th Feb 2009, 02:31 -
dvd burn fails in all software authoring programs
By jfrenchu in forum Authoring (DVD)Replies: 8Last Post: 9th Feb 2008, 23:39
