Results 1 to 9 of 9
  1. Hi.... Friends
    I am a new excuse not find the link I had to turn about
    How can I write text to the original DVD menu
  3. thank you
  4. Originally Posted by cavusozkan View Post
    Also (using freeware):
    https://forum.videohelp.com/threads/254043-Guide-for-extracting-menus-for-editing-and-r...00#post1514500
  5. Originally Posted by Baldrick View Post
    I was writing the original film, but again, the original menu and how I will integrate
  6. friends I've added the original logo to the menu, but again DVDremake How can I integrate. I did, but the player but VLC player VIDEO_TS folder at the menu screen when I do come. you can help in this regard
    Oct 2006
    Canada
    If you use Remake, you will need VOB file. The way to do this from beginning is to
    Load your project to DVDRemake, find your menu, right click on the picture, drop down window open, click "Export frame".
    You get BMP file which you can modify in any photo editor.
    Get MuxMan (free), load your BMP file there and save as .M2V file, in the same MuxMan window, under File, Click Save and exit.
    After new window open Add your M2V file, delete BMP file, and close. In Muxman original window locate where you want to save the finish file and click on Start.
    Open Remake, Right click on your old menu picture, click on "Replace with still" locate your muxman file by clicking "Load" and insert in Remake. New menu will appear.
    You are done
  8. Thanks for information now that they did write was excellent, thank you again
    Oct 2006
    Canada
    You can also check out DVDRemake web site. It has pretty good help info there.
    Good Luck, hope it works for you.
