Hello,
I have an WMV file and I would like to play it using my DVD player - Pioneer DV310.
How can I convert it to AVI / DivX / Xvid, in a simple & freeware conversion tool?
I was looking at the convert section, but couldn't find one tool for this.
Thanks,
Uriel
Check out Stoik Video Converter (simple converter) or AVIDemux (lots of editing/enhancement filters).
Thanks: I have downloaded STOIK which is very simple to convert.
My original WMV file is 24 minutes & 130MB.
I have tried to convert it to DV / DivX / AVI but I could not succedded playing the file in my Pioneer player DVD.
Which format I would need to use?
Thanks,
Uriel -
The Pioneer DV310 can play Divx AVI. Be sure not to exceed what the player can handle. Frame sizes over 720x576 for example. Common Divx/DVD player limitations:
https://forum.videohelp.com/threads/295067-Common-DivX-DVD-Players-AVI-Playback-problems! -
Try using divx converter to convert your wmv and see if that plays.
Quote: Which format I would need to use?
Either DivX or XviD should work. If you're using Stoik, you'll need to set the codec specs under the video "compression options" -- select "advanced" at the botton of the drop-down menu, pick your codec, and make the necessary adjustments (bit rate, etc.).
how to convert wmv to avi for dvd playback[divx support]
By gundja in forum Video ConversionReplies: 4Last Post: 18th Mar 2009, 13:32 -
Playing HD (.mkv) and XViD\DiVX (.avi, .wmv)
By yonyz in forum Software PlayingReplies: 10Last Post: 25th Feb 2009, 14:18 -
wmv to avi (divx/xvid) conversion jumpy output file
By famine99 in forum Video ConversionReplies: 5Last Post: 14th Oct 2007, 12:09 -
By famine99 in forum Video ConversionReplies: 0Last Post: 11th Oct 2007, 22:04 -
I need to convert dvd into avi!not xvid or divx!
By picky2112 in forum DVD RippingReplies: 5Last Post: 6th Jul 2007, 03:22
