For DVD architect users!
Is it possible at the end of a chapter to come back to the chapter menu instead of continuing playing the all movie automaticly. What i want to do is defined the beegining and the end of a chapter so when you play it , just the chapter would play and then come back to the menu .
	You would need a chapter playlist, which I don't believe DVDA supports (at least not up to Pro 4.5) or you would have to put logic codec behind the playback to manually control the end action of the chapter. DVD Lab Pro supports chapter playlists, which would make this exercise a doddle. Read my blog here.
	You can add the same moviefile as often as you like (will only be physically present once.)
 Than you can create new in and out on each file, each with his own access from the menu.
 Just move the sliders.
	Thanks guys!!
 I been posting in a few forums and no answers...
 I will try what you said NoBuddy it seems to be the way to go. it seems to be the way to go.
	I tried it and it does'nt work...When i create an in and out it will only play that part on all the other ones too...
 Does anybody have an other idea?
	Use a better authoring tool. DVD Lab Pro would do this without breaking a sweat Read my blog here.
	NoBuddy is correct. Simply select the link on the menu and copy and paste into the same menu as many times as you have chapters. After pasting, you will notice that the project pane will also duplicate the instances of the file. Choose each new instance and set unique in/out markers (at your chapter points). Repeat as many times as necessary. The movie file will only be recorded once on the dvd but each separate instance will become a unique PGC.
 It is a difficult concept to first grasp, but once executed a few times it becomes second nature.
 -Smells_Like_Feet
  Default Chapter title - DVD Architect 5.0By KayAt in forum Authoring (DVD)Replies: 2Last Post: 23rd Feb 2010, 05:11
  DVD Architect 5.0By Mr. Robinson in forum Authoring (DVD)Replies: 1Last Post: 4th Nov 2009, 11:59
  GUI for dvdauthor - How to make chapter thumbnails run the chapter videoBy deco81 in forum Authoring (DVD)Replies: 4Last Post: 15th Dec 2008, 12:51
  DVD Architect helpBy monks19 in forum Authoring (DVD)Replies: 11Last Post: 23rd Aug 2007, 07:46
  DVD architectBy Abiyad in forum EditingReplies: 1Last Post: 19th May 2007, 09:02
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
