Results 1 to 10 of 10
Thread: no options in audio compression for virtual dub
  1. #1
    Hi,
    New to all this, i have one problem in my way. I am converting an avi that has ac3 audio into mp3 so it plays in coreplayer on my phone.
    I'm following a guide which i understand but when i go into audio compression and select lame mp3 or any of the other options nothing comes up in the right hand pane for me to select
    this is the bit from the guide:
    At Audio > Compression select the MPEG Layer 3 codec. At the right field, chose the desired audio bitrate and mode, matching the sampling rate from the original audio stream (44 Khz or whatever). Recommended audio quality values for small file sizes are between 96 and 128 Kbps.
    The only option that has stuff in the right hand pane is the ac3 selection.
    Where am i going wrong? i have installed lame mp3
    thanks
    Member
    Feb 2008
    Twin Peaks
    Posts
    1,009
    Re: no options in audio compression for virtual dub
    Did you set the audio to "full processing" mode?
    Quote Originally Posted by lowellriggsiam View Post
    Yeah i got all that down....
    ok, so i worked out that the options are there for files that dont have ac3 audio!! as soon as i put an ac3 audio avi in, the lame options dissapear
    is there a reason for this?
    all i wanna do is convert ac3 audio into mp3 audio for my film. Is there another way of doing this procedure,? i just dont get why it wont let me do it, very frustratimg
    Member
    Feb 2008
    Twin Peaks
    Posts
    1,009
    If wanted to do that I'd use Sony Movie Studio. I can see, however, this has been a problem before http://www.videohelp.com/forum/archive/virtualdub-ac3-t370672.html
    Thanks for that, have you got that software? could you tell me what options to choose for it?
    Member [_chef_]'s Avatar
    Nov 2002
    Germany
    Posts
    931
    virtualdub will work with the right codecs installed!
    *** Now that you have read me, do some other things. ***
    Quote Originally Posted by [_chef_] View Post
    can you suggest what im missing? i have the codecs, as stated, it works when when a non ac3 file is selected. im using avidemux now, works fine
    Member
    Nov 2002
    Posts
    3,227
    In Virtualdub, under Audio, choose Full Processing Mode > choose Conversion and change 6 channel to Stereo > choose Compression and you should now be able to choose Lame MP3.
    Quote Originally Posted by DarrellS View Post
    Yes, THANKS! it was the changing the 6 channel to stereo i was missing. Much appreciatted
    Member
    Nov 2002
    Posts
    3,227
    You're welcome!
  1. Virtual Dub say's No audio decompressor to decompress source audio
    By s_joy09 in forum Newbie / General discussions
    Last Post: 25th Dec 2011, 14:03
  2. problem with compression using virtual dub
    By jpez1 in forum Video Conversion
    Last Post: 3rd Aug 2010, 13:24
  3. No Video In Virtual Dub, Just Audio
    By AllenM in forum Editing
    Last Post: 3rd Oct 2008, 13:35
  4. Virtual Dub Audio Not In Sync
    By RKelly in forum Editing
    Last Post: 28th May 2008, 19:45
  5. Audio out of sync after running file thru virtual dub
    By AORMan in forum Video Conversion
    Last Post: 2nd Oct 2007, 13:35
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
