Results 1 to 11 of 11
  1. Fellows I am in need of a new pc. I am low on funds and found this one. Acer Aspire X1300-U1801A : 2.4GHz Athlon X2 3GB RAM 320GB hard drive. Here are the specs, and I am willing to take the risk on it being a refurb. Also, I do not do any gaming.
    Audio
    Audio Output Type Sound card
    General
    Chassis Form Factor Desktop
    Refurbished Type Refurb.
    Memory
    Cache Memory (installed) 1 MB
    RAM (installed) 3 GB
    RAM (max) 4 GB
    RAM Technology DDR2 SDRAM
    Modem
    Modem Type Modem
    Modem Type Fax
    Modem Protocol V.92
    Operating System
    OS Provided Windows Vista Home Premium
    Optical Drive Information
    CD/DVD Type DVD Super Multi
    CD/DVD Type Labelflash
    Processor
    Chipset Type NVIDIA GeForce 8200
    # Processors Installed 1
    # Processors Supported 1
    Processor Model Number 7450
    Processor Speed 2.4 GHz
    Processor Manufacturer AMD
    Processor Type Athlon X2
    Protocols
    Networking Protocol Gigabit Ethernet
    Networking Protocol Ethernet
    Networking Protocol Fast Ethernet
    Standards
    Compliant Standards PC 2001
    Storage
    Hard Drive Capacity 320 GB
    Hard Drive Interface SATA 3.0 Gbps
    Video
    Video Card NVIDIA GeForce 8200
    Video Slot Type PCI Express 2.0 x16
    Contents System unit, USB keyboard, USB mouse, speakers, software, documentation
    General Information Features:
    5.1 channel surround sound, high definition audio support
    Memory Notes 3GB DDR2 SDRAM, expandable to 4GB. There are two memory slots, both are occupied
    Feb 2008
    Twin Peaks
    Now that you've eliminated gaming, what would be your primary purpose?
  3. Basically surfing, small video clip editing with virtualdub, and watching vids and music.
  4. How much $$$$ ?
  5. $229.00 free shipping, no tax
  6. Can you upgrade the graphics to Nvidia 8600+ or ATI 2400+ ? That will give you the option of graphics hardware video decompression.
  7. http://www.techbargains.com/news_displayItem.cfm/197099
    try to stay away from slim cases. they are not easy to upgrade/add on
    plus Acer is known for not including any software/backup with their pc's/laptop.my brother in law's laptop didn't come with a single cd
    what do u think about the Dell Zino HD Media Center Desktop w/ Radeon HD3200 Graphics
    The only thing I don't like is the single core CPU. enough power for net
    http://www.techbargains.com/news_displayItem.cfm/197085
    Feb 2008
    Twin Peaks
    It's not bad for the price, in the end you get what you pay for.
  9. Buy it.. two cores .. Not an ATom gfx slot if you ever feel like upgrading the gfx. Acer are Ok.
    The electronic components of the power part adopted a lot of Rubycons.
    Aug 2006
    I looked up the detailed specs in another website. It doesn't seem like a bad choice for what you want to do with it, but I noticed one thing that is a little worrisome. The PSU is only 220W. It's an SSF case, which means if you need to replace or upgrade the PSU, it is likely a standard PSU won't fit and your choices will be limited.
  11. Member lacywest's Avatar
    Aug 2001
    California
    I was looking at these a few months ago on Ebay ... I have been buying one certain ACER model and I like it ... I've gotten a few that didn't work correctly. But it was a matter of changing the mother board to fix it.
    So I started looking around for more models by Acer and found this ... that your interested in. I even bidded on some of them. I then started to look around for them on the Internet ... I am glad I didn't win them. They are proprietary to the max. If I wanted to modify it ... I would be screwed.
    If you get it and the mother board starts to fail ... well you can gut it ... and use the parts else where. Good luck with the Power Supply in it ... it is not a standard Power Supply like you find in other normal common PC towers.
