Hi,
I need info about the best settings to used mp4 videos in PS3.
I have many trailers in QT with Profile Main@L4.0 downloaded form apple, and mp4 files with this profile or I need to used High@L4.0 or High@L4.1 ?
Friends a VideoHelp post the settings that you used to have a better idea,
Thanks in advance.
You should let let your encoder use autolevel. Although the PS3 is capable of playing 4.1, since it's a blu-ray player, there is a ton on content out there needlessly marked as 4.1 even though everything else about the file is within 4.0 or less.
If you're looking to make content that plays nice with multiple devices, we recommend the following x264 and HandBrake presets:
DivX Plus compatible settings for x264:HandBrake advanced settings:Code:x264 --vbv-maxrate=20000 --vbv-bufsize=25000 --level 40 --bframes 3 --keyint <4*FPS> -o <output file> <input file>
Our recommendations are further explained here:Code:level=40:ref=2:bframes=2:subq=6:mixed-refs=0:weightb=0:8x8dct=0:trellis=0:vbv-maxrate=20000:vbv-bufsize=25000
http://developer.divx.com/docs/divx_plus_hd/Creation_with_x264/
So these should work for the Playstation 3 as well as across many other H.264 devices. -
Hi, Porfitron.
Thanks for your reply and for share your encoding settings.
need encoding tips for better quality PS3-friendly MP4
By spicediver10191 in forum Video ConversionReplies: 6Last Post: 13th Mar 2011, 05:48 -
Converting to PS3 .mp4 with MP4 Converter on Mac
By The Sumerian in forum MacReplies: 2Last Post: 29th Dec 2008, 21:24 -
Large MKV (h264) File to PS3 MP4 without re-encoding
By icue in forum MacReplies: 0Last Post: 29th Sep 2008, 18:14 -
PS3 Video 9 - .AVI to PS3 - Settings
By dec60228 in forum Video ConversionReplies: 0Last Post: 22nd Feb 2008, 13:48 -
Best settings for encoding with subtitles and then re-encoding for PS3?
By bish73 in forum ffmpegX general discussionReplies: 5Last Post: 21st Jul 2007, 00:31
