Results 1 to 30 of 49
    Dec 2009
    I have a video file in mp4 format at 25 fps. When I watch it in a media player such as mpc there appear to be combing artifacts as seen below even though it seems to have been IVTC. How can I convert the footage to 23.97 fps with vdubmod and avisynth etc?
  2. post a native sample
    Dec 2009
    Can't it's too many mb. Stop stalking me.
  4. You can't tell enough from a single frame. Use AviDemux, mark a short (~10 seconds) section with motion, save in Copy mode.
    Dec 2009
    Besides the point, all of you people: "poisondeathray", "jagabo", "AlanHK" and others. You know who you are. It's painfully obvious what you're doing. You have no right to manipulate this forum. It doesn't legally belong to you. Stop stalking me and responding to every single thread I make while blocking REAL users and regulars on this forum from responding to them. Badrick, a little help?
  6. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Deleted.
  7. Originally Posted by Eva-Unit01 View Post
    WTF....You're joking right?
    Dude just look at jagabo's post count. He's helped like 1000's of people
    He's explained why a sample is necessary. You're allowed to post a sample under fair use laws in USA and Canada.
    LOL sorry for trying to help out
    Cheers
  8. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Sorry, it's only painfully obvious to me that you're a nutcase.
    So I'll delete the earlier post I made that answered your question and let all those REAL users and regulars deal with you.
    I've added you to my Ignore list so I won't be tempted to answer any of your posts in future.
    Bye.
    Dec 2009
    Why the sudden turn to hostility?
  10. A response to your hostility?
    Dec 2009
    Samples
  12. That's 29.97 fps interlaced video (59.94 fields per second) that was compressed as if it was progressive. You can force deinterlacing during playback in a media player or deinterlace and reencode. For example:
    DirectShowSource("Anno clip 1.mp4")
    AssumeTFF()
    Crop(4,0,-0,-0)
    ConvertToYV12() # I have CoreAVC set up to output YUY2 only, TempGaussMC requires YV12
    TempGaussMC_beta1mod()
    That will give you a smooth 60 fps video. Add SelectEven() to reduce it to 30 fps.
    If you want something faster (TempGaussMC is very slow) try Yadif(order=1) for 30 fps, Yadif(mode=1, order=1) for 60 fps.
    Dec 2009
    So the source file was just compressed without inverse telecining? I don't want to deinterlace it all at once. What would the script have to look like to just decode the video too it's original interlaced 29.97 fps form? Couldn't it just be IVTC'd after decoding?
  14. IVTC is for telecined film. This isn't film, therefore no IVTC.
    Dec 2009
    Well what is the sample video then? The above code did not work. Tempgaussmc is not a recognized command.
  16. You need to download and install all the appropriate filters for TempGaussMC_beta1mod().
    http://avisynth.org/mediawiki/TempGaussMC#Required_Plugins
    Dec 2009
    AssumeTFF()
    Crop(4,0,-0,-0)
    What exactly will this script do? Step by step. Was the source footage telecine? Lastly, are all the codes necessary? Could the Anno footage just be decoded to interlaced YV12 lossless AVI file @ 29.97 frames per sec. and then be deinterlaced?
  18. Oops, wrong answer
  19. As jagabo said just below the script, it bobs it to progressive 60fps. You can make it 30fps by adding SelectEven() below the TempGauss line.
    What do you want to do with this thing? If for DVD, do a proper resize (708x480 is non-compliant) and encode for DVD as-is - by keeping it interlaced.
    No, it was never telecined. It was shot using an interlaced 29.97fps video camera. And if you really want to deinterlace it (why?) you can do that in the script without making a lossless AVI.
  20. DirectShowSource("Anno clip 1.mp4")
    Opens source file.
    AssumeTFF()
    Tells AviSynth the frames are top field first (interlaced).
    Crop(4,0,-0,-0)
    Removes 4 lines from the left side of the frame to make it mod 16 (and there was some black border there anyway.
    Converts YUY2 to YV12.
    A very smart bob deinterlacer that converts each field into a frame using data from other fields/frames to fill in the gaps.
    Dec 2009
    My point is, why does the resulting file have to be halved 30 fps if it will already be deinterlaced? Are you saying that doing the above operation will completely eliminate the combing artifacts? I assume that 30 fps in not the same as progressive footage and thus my question, "how do i convert this footage to 23.97 fps and eliminate the combing artifacts?" is not being answered. Would I have to change the fps rate after the TempGauss plugin completes the edit?
    My understanding is that all footage ripped from DVD as a VOB file is in telecine form (29.97 fps). Why then, does this footage which I know for a fact was ripped from DVD, not have to be Inverse Telecined, and thus converted to 23.97 frames per second (progressive)?
  22. Originally Posted by Eva-Unit01 View Post
    Some DVDs are made from video (not film) footage which is 60 fields per second packaged into 30 interlaced frames per second on the DVD. You cannot create 24 progressive frames per second from 60 fields per second without getting jerky results because 60 is not integer multiple of 24 (2.5). You can create 30 progressive frames per second that plays pretty smoothly because 60 is an integer multiple of 30 (2).
  23. Originally Posted by Eva-Unit01 View Post
    That's what a deinterlacer does - it gets rid of the interlacing (combing, mice teeth, call it what you will). However, if this thing is movie length (as opposed to being music video length), you might find that TempGauss takes too long. You might be happy with a much faster deinterlacer, one like Yadif.
    I assume that 30 fps in not the same as progressive footage...
    Your source is interlaced, and after being deinterlaced it'll be progressive. The framerate has nothing to do with whether it's progressive or interlaced.
    ...thus my question, "how do i convert this footage to 23.97 fps and eliminate the combing artifacts?"
    You don't. You keep it at 29.97fps and eliminate the combing artifacts (by deinterlacing). That's even if it has to be deinterlaced. You've provided no reason at all yet why it has to be deinterlaced.
    Leave the framerate alone.
    Your understanding is completely and utterly wrong. jagabo explained why.
    Because it's not sourced from film, but from video.
    Just as an aside, why is this thread entititled 25 fps to 23.97 fps (film)? Nowhere does 25fps even crop up.
  24. Member
    Dec 2009
    AssumeTFF()
    Crop(4,0,-0,-0)
    What are all the plugins needed for the tempgauss command. I have MVtools, removegrain, masktoolsv2 and eedi2.
  25. Follow the link I gave you earlier. And put TempGaussMC_Beta1mod.avis in your plugins folder.
  26. Member
    Dec 2009
    I did. It still says an error "There is no command called 'msuper'" within the tempgauss script.
  27. MSuper() is part of MvTools. Make sure you have the right version.
  28. Member
    Feb 2009
    Hellas
    I found this pieece of ....
    "Politely" i could get more by the members.
    DirectShowSource("C:\Users\...\...\video's name.mp4", fps=25, convertfps=true)
    ConvertToYV12()
    Lanczos4Resize(720,480)
    AssumeFPS(23.97)
    Gentlement :
    You owe a "gui", software, or something (made by you) for the forum...!
    Thanks.
  29. Originally Posted by chrchr View Post
    ConvertToYV12()
    AssumeFPS(23.97)
    That would be a disaster.
