  1. i'm using Xvid4PSP to hardsub a anime. After which i upload a small part to youtube to test the hardsubs on youtube. But it doesn't appear. Can anyone help me?
    Then is not xvid4psp hard subbing because youtube can't remove any burned in subs.
    What xvid4psp version are you using? I guess you are loading the subs manually?
  3. Originally Posted by Baldrick View Post
    I used version 5. Not sure what loading the subs manually means but i go subtitles>>add>> encode.
    I'll download version 6 and give it a shot .
    EDIT: Ver 6 doesn't seem to support add in subs, guess i'll re-install ver 5
    EDIT: I made a mistake earlier on it was meGUI and i had the subs turn on that i was using and not xvid4psp.
    So here is my problems:
    In the preview of xvid4psp i can view the subtitles in the video but after i encoded it using xvid4psp, the subtitles doesn't appear in the encoded video. Anyone?
    EDIT: Nvm i fixed it =)
