Hi,
I'm trying to convert some MKV and OGM files to mpeg2 AVI, via Avisynth frameserving.
I prefer mpeg2 instead of divx, xvid, etc. because of the greater portability.
However, in VDub's Compression menu I cannot find any option for the mpeg2 codec.
Is there any plug in or some way that enables Vdub to encode into mpeg2?
I decode the sound separately and I have no problems with it.
Thanks.
Vdub doesn't encode to Mpeg-2. There was one encoder that could plug into vdub, but I cannot recall the name. It was payware, however.
If you are already using avisynth, why not serve directly to HCEnc and encode the video that way. No need for vdub in the mix at all, really.
All that is left after that is to mux the two together to get your MPG file.Read my blog here.
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
How to play MKV, MKV to AVI, MKV to DVD, MKV to Xbox 360 or Playstation 3
By Baldrick in forum Video ConversionReplies: 2Last Post: 8th Mar 2012, 03:45 -
ts --> mkv, do I need tsMuxer+mkvMerge or vDub is enough
By adom in forum Video ConversionReplies: 17Last Post: 26th Jan 2011, 19:41 -
MKV -> MPG2 for HD-DVD Authoring
By Mickey79 in forum Video ConversionReplies: 18Last Post: 13th Feb 2008, 09:38 -
Problem converting HD (.mkv) to DVD (.mpg2) with TMPGEnc
By KPKMP33 in forum Video ConversionReplies: 4Last Post: 9th Nov 2007, 10:36
